I like transparency. Here are the fault codes I got today. The last one is a stored one from July 30, 2012.
Monday,24,February,2014,14:26:26:03487
VCDS Version: Release 12.12.2
Address 01: Engine Labels: 038-906-016-BEW.lbl
Control Module Part Number: 038 997 016 R HW: 028 101 181 2
Component and/or Version: R4 1,9L EDC G000AG 0282
Software Coding: 0150034
Work Shop Code: WSC 26105 444 85824
VCID: 2D5FF4A9B71CA176001-513C
4 Faults Found:
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2058 /min
Torque: 122.0 Nm
Speed: 27.0 km/h
Load: 80.4 %
Voltage: 14.14 V
Bin. Bits: 00001100
Absolute Pres.: 1866.6 mbar
Absolute Pres.: 816.0 mbar
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 110.0 Nm
16791 - EGR Sensor 2
P0407 - 000 - Signal too Low - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -2.5 %
Mass Air / Rev.: 1000.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Bin. Bits: 00000000
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001111
Torque: 0.0 Nm
Torque: 110.0 Nm
Readiness: 0 2 0 0 0
Tramsmission
Monday,24,February,2014,14:30:05:03487
Address 02: Auto Trans Labels: 09A-927-750.lbl
Control Module Part Number: 09A 927 750 BL
Component and/or Version: AG5 Getriebe 09A 0262
Software Coding:
Work Shop Code:
VCID: 76ED1BC552CAA2AEB1B-513C
2 Faults Found:
00300 - Transmission Fluid Temp. Sensor (G93)
27-10 - Implausible Signal - Intermittent
00526 - Brake Light Switch-F
28-10 - Short to Plus – Intermittent
Sunday,10,June,2012,13:19:18:03487
VCDS Version: Release 11.11.3
Data version: 20120401
Address 01: Engine Labels: 038-906-012-AGR.LBL
Control Module Part Number: 038 906 012 CP
Component and/or Version: 1,9l R4 EDC G000AG 2839
Software Coding: 00001
Work Shop Code: WSC 00000
VCID: 60C15D9DE058829
1 Fault Found:
17656 - Start of Injection Timing Regulation
P1248 - 35-00 - Control Deviation
Readiness: 0 0 0 0 0
Monday,30,July,2012,16:32:11:03487
16:32:03
91.8°C Coolant Temp 80-110
91.8°C Coolant temp
55.8°C Fuel Temp
30.6°C Intake Air Temp
Wednesday,26,June,2013,16:28:24:03487
VCDS Version: Release 11.11.6
Data version: 20121223
Address 01: Engine (038 906 012 CP)
16:28:22
1.560 V Mod. Piston Disp. (G149)
903 /min Engine Speed (G28)
116.1°C Coolant Temperature (G62)
355.0 mg/str Mass Air Flow (Actual)
805.8 mbar Air Pressure (F96) BARO
826.2 mbar Manifold Pressure (Actual) MAP (G71)
Wednesday,01,January,2014,19:12:23:03487
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Address 01: Engine Labels: 028-906-021-AHU.lbl
Control Module Part Number: 028 906 021 FA
Component and/or Version: 1,9l R4 EDC G10SG 1405
Software Coding: 00002
Work Shop Code: WSC 00046
VCID: 53AB8251A1F8D786791-4B18
6 Faults Found:
01265 - Exhaust Gas Recirculation Valve (N18)
31-10 - Open or Short to Ground - Intermittent
01117 - Generator Terminal DF Load Signal
27-00 - Implausible Signal
00542 - Needle lift Sensor (G80)
30-00 - Open or Short to Plus
00539 - Fuel Temperature Sensor (G81)
30-10 - Open or Short to Plus - Intermittent
00626 - Glow Plug Indicator Light (K29)
Readiness: N/A
Address 01: DTCs cleared
Address 01: DTCs clearedMonday,24,February,2014,14:28:47:03487
VCDS Version: 12.12.2.0
Data version: 20140212
Address 01: Engine (038 997 016 R)
14:28:43
11.2 °BTDC Injection Start (specified)
6.1°KW Injection Duration (specified)
345.0 mg/str Mass Air Flow (actual)
1030.2 mbar Boost Pressure (specified)
785.4 mbar Boost Pressure (actual)
