Toddhess92
So I've been in the process of building up my 03 alh with the following mods.
Southbend Stage 2 endurance
DLC1019
Stage 3 malone
Have replaced all the following with all oem
MAF
N75
Vacumn lines and one way valve (routed per diagram on the fourm via deletes)
The car seems sluggish to me to what it should be imo after all the mods too, my family has a bone stock 03 ALH golf that has more pull i feel when you get on it. The only thing that seems off to me is the car straight piped use to sit and idle with a loud turbo whine, lately upon start up it does but after you drive it and come to an idle the turbo noise is very faint. I pulled the actuator off and it moves very free no binding or anything I tested it as well and it pulls smooth. The arm on my turbo I can move freely up and down, but I can also pull it up even further (towards the hood) and it has some binding then. I reinstalled the actuator and checked and it does not start moving untill 4 and is all the way down around 18 smoothy which seems to be in spec so I'm at a lost. I have some vcds info as well. Thanks
DLC1019
Stage 3 malone
MAF
N75
