crisp006
Hi guys.
I recently changed the gear oil in my Jetta with an 02J transmission. I added about 2 litres but did so with the transmission out of the car and at an angle, so was not able to reference the fluid level by way of the fill plug.
As it turns out, the transmission must not have 100% drained as it has been slowly leaking (excess) gear oil and, upon removing the filler plug, the transmission began draining gear oil. A total of probably 100-250mL drained out with the car *somewhat* level. It is on jack stands so it’s not perfectly level.
My question:
Although it has now stopped leaking oil, can anyone tell me how it would’ve leaked to begin with? As best I can tell it was leaking from the bottom of the bell housing where the transmission meets the engine.
I read that there is a vent near the top of the shift tower, but then read elsewhere that the transmission cannot drain from there unless the car is upside down...
My main concern is if the transmission would’ve vented the gear oil out in such a way that it would’ve oiled up the clutch... in which case I am going to have to begrudgingly take the transmission out and fix that issue.
anyone have any insights?
thanks in advance.
My question:
thanks in advance.
