RicMck
Hi Today I removed and replaced a bunch of fuses to determine a good circuit that is only "on" when the car is on to install some LED DRL. After that I got Airbag light and a #02511 fault code. The fault code is 02511 Seat occupied module. No one was in the seat. And I tried sitting in the seat and the code & light are still on positive. I cleaned the 3 connectors at the floor, checked #3 fuse, and the code will not stay cleared.
Is it the wires under the seat or the module How do I determine if it is the module?
If it's the module, is it OK to get a used one? If yes does the dealer need to calibrate it after I put it in?
Tomorrow I will remove the seat and check the continuity of the wires from the floor connector to the module. Are there specific precautions I need to take to be sure I don't deploy the seat airbag?
Are there any known issues with the wiring from the floor connectors forward? If yes here should I look and how can I check them?
Thanks.
Thanks.
