I have not been driving this Jetta much, and was yesterday and to my surprise no AC. It worked the last time I drove the car in the summer (probably last year).
So when I got home did some quick diag work: Blend door was working (air got much hotter when temp switched to hot). Rad fans work, heard and saw them come on when waiting at lights, although maybe not at high speed. Hard to say since I rarely hear/see them in use. When the AC dash button is pressed in, the light comes on, which I think means the fuse is OK. With the vent fan on and AC button on, the compressor clutch is NOT engaged (turning), and neither rad fan comes on???
In checking various posts, I thought it might be the infamous 384 relay, so I pulled the lower dash panel and took a look at the relays. I did not see any 384 relay under there???
So, I guess my questions are:
Which is the AC relay and where did they hide it?
And besides the relay is there any other diagnostics I can do without a set of AC gauges?
