The turn signals on my 01 Golf are acting up. They flash once (occasionally twice or so) when the turn signal level is moved to right or left; then they stop flashing. If the emergency flasher button is pressed in, everything flashes just fine.
So I am wondering if this is enough diagnosis to lay the blame at the turn signal switch? Wanted to be sure before going thru replacing it. Seemed that if the emergency flashers work, then it isn't the flasher unit (is that right?) Anything else worth checking here before I order a new turn switch assembly?
TIA
TIA
