Old February 26th, 2018, 18:14   #1
Rented_Sperry
TDI(s): 00 Jetta ALH
Default 2002 Jetta tdi lock problems.
hey guys. just had the weirdest experience and was hoping you guys could throw in a helping hand.
So i just bought a 2002 jetta tdi for my dad. i have a lot of experience with these. but not in this area.
So the window was stuck. took apart drivers door and found the wire was wrapped around the motor a couple of times. i have plenty of spares so i changed the whole inner panel. tried to undo all windows, nothing. tried my window, nothing. unplugged clip for window motor and plugged back in , worked fine. but only my window, i cant undo the passenger window from the drivers side, but i can if i use the switch on the passenger side. so i tried a different window switch, window motor and still no luck, checked fuse 14 and its good. im leaning towards this being more of the door lock actuator and that "my 3$ fix forum".
the weird thing is i can unlock every door with no problem except drivers, let me know what you guys think? i did dielectric grease almost all my connectors in the door but didnt help. im stuck here....
Rented_Sperry is offline   Reply With Quote
Old February 27th, 2018, 14:45   #2
Diesel_K82
TDI(s): 2004 Jetta
Definitely sounds like a typical gremlin. I have an issue where I can unlock all doors with the button, but the drivers side will not lock by power. I also can’t use the key in the door to lock/unlock. I think I need to replace the lock module.
Diesel_K82 is offline   Reply With Quote
Old February 27th, 2018, 16:10   #3
P2B
P2B's Avatar
Possibly broken wires inside the bellows between the driver's door and the body - common problem.
Simon
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is offline   Reply With Quote
Old February 27th, 2018, 17:17   #4
Palka3
Fuel Economy: 47-52
This is not a gremlin. This is part of VW's safety system. I had a similar problem years ago.
I believe to correct this you have to sit in the passengers side seat with the door closed, then unlock/lock the doors on the passengers side using passengers side switch. If that doesn't work insert the key in the ignition and repeat.
Go to http://forums.tdiclub.com/showthread.php?t=355194 for more tips Good luck.
Palka3 is offline   Reply With Quote
Blinker Problems 2002 jetta tdi ProTaper125 TDI 101 5 March 7th, 2013 17:55
Trunk Problems 2002 Jetta TDI ProTaper125 TDI 101 6 October 1st, 2012 01:54
Electrical Problems - 2002 Jetta TDI LowHanger VW MKIV-A4 TDIs (VE and PD) 4 June 30th, 2008 19:02
2 problems with my Jetta 2002 TDI bluejetta02 TDI 101 18 December 5th, 2006 10:25
TDI 2002 Jetta Drivers door lock LED ON sauria VW MKIV-A4 TDIs (VE and PD) 5 November 2nd, 2004 08:50
Page generated in 0.13596 seconds with 10 queries
[Output: 63.42 Kb. compressed to 56.90 Kb. by saving 6.52 Kb. (10.28%)]
