Old June 12th, 2012, 17:17   #1
harken
Default Remote won't unlock passenger or rear doors
I recently changed the battery and now the remote will not unlock either the passenger or rear doors. Will unlock the drivers side door and rear hatch (wagon). There is the familiar dlicking sound like it is working, but doors do not unlock. Power switch on drivers side console will unlock doors. Any ideas,
harken is offline   Reply With Quote
Old June 12th, 2012, 18:21   #2
Lloydw
Fuel Economy: 40
What year, and model? Mine is 2005 Passat and the remote was dead when I got my car. I installed a new battery in remote and the only response I get is the red led on the remote comes on when I push the 3 buttons. I have the VCDS and tried to program the remote with no success. The instructions are not the best for my simple mind. I need very plain directions, step by step. I'll keep an eye on your notes. Same problem. Thanks. I like my used Passat.
Lloydw is offline   Reply With Quote
Old June 12th, 2012, 18:43   #3
Seatman
Seatman's Avatar
Fuel Economy: No idea
Is it the same as the Mk4 golf where the default setting is that you have to press the unlock button twice to unlock all doors or once for just the drivers door?
If so I'm sure that's just a vagcom setting
Seatman is offline   Reply With Quote
Old June 13th, 2012, 06:26   #4
hysterwv
Harken, I'm not in a place to look it up, but there's a procedure for this. Did you try searching? I can't recall precisely, but it was something like put the key in ignition, turn to acc, then push the unlock button.
hysterwv is offline   Reply With Quote
Old June 13th, 2012, 09:53   #5
harken
Thanks for all the replies. A couple of clarifications....the car battery was changed, not the remote battery. It is a 2004 passat wagon. Ususal procedure is to press twice to unlock the passenger/rear doors. hysterwv, I'll give your procedure a try.
Thanks again
Old June 13th, 2012, 10:09   #6
harken
Found the fix...just had to unlock/lock the doors on the passengers side using passengers side switch. Remote now will unlock them.
Old March 26th, 2013, 10:04   #7
ERICandMilousTDI
I have the same identical problem with my Jetta Wagon 03 TDI.
I had to boost the battery last week and now I have the same situation.
I will try the passenger's side switch tonight and update you.
Thanks for the Heads Up.
ERICandMilousTDI is offline   Reply With Quote
Old March 30th, 2013, 16:56   #8
JerryKib
Fuel Economy: 46/41/36;45,35,30
We were also having the unlocking problem on the front passenger side door. I just tried your suggestion on our 2004 Passat wagon. It seems to have worked.
Jerry Kibby
01 Golf GL TDI(auto) DG skid plate, ventectomy, PP357, RC2, stainless 2.5" exhaust
2004 Passat GLS wagon TDI, Geared BS Module,
Steel Glow Plugs, Evo skid plate
JerryKib is offline   Reply With Quote
Old May 22nd, 2014, 14:08   #9
indysoto
indysoto's Avatar
Default Reset Key Fob unlock all doors including Drivers door by mucking about?!
Let Me Be sure I have this Procedure down..
If you have 2 good keys
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
Models Covered:
'· Lupo
'· Polo
'· Golf
'· Bora
'· Passat
'· Sharan (Only Mk2 models as far as I know though)
Source:
You also need to go here: http://forums.vwvortex.com/showthread.ph...
the internet in this instance is your friend, you need to join up and discuss your problem with the board members specifically for your car. Hope I led you in the right direction anyways. Hope this helped.
2000 a4,G60 single mass, KYB AGX(replaced 2x :|), 215/65/r16's...
2004 BEW Wagon w/ Meyerhoff AutoHaus Runonbeer Sticker
indysoto is offline   Reply With Quote
Old May 23rd, 2014, 10:31   #10
indysoto
indysoto's Avatar
Default Did not work Unlock and all doors unlock not working
And That procedure in a 2003 Passat did not work...
fiddling around with passenger door did not produce any result.. Time for the VCDS to scan comfort controll module
and then probably this ingenious reset by Jettscuba..
Hi, I know this is an old thread.
I just had a Polo TDI where the lock button worked, the boot button worked, but the unlock not. Scanned the comfort module, checked and reprogrammed the keys, no luck.
Then I put a new battery in, no luck.
Then I shorted the + and - battery terminals on the pcb inside the keyfob (battery removed please!), put the old battery in, and it worked. Same for the second remote. Happy client! After he had a frustrating and potentially expensive trip to the dealers - they wanted to sell him new keys - okay, it probably would have solved the issue too...
I suspect a latched-up condition occured inside both keyfobs.
Silver VW Jetta A4 TDI 2002 AHF, 389 000km
(VCDS Hex + CAN, ALH/AHF tools, BRM/BEW tools)
Old May 23rd, 2014, 10:40   #11
indysoto
indysoto's Avatar
Then I put a new battery in, no luck. Jettascuba
Old May 26th, 2014, 12:03   #12
gotsoot
Fuel Economy: 41 and looking for more
had dead car battery,then doors would not lock.read the above post for fix.wah-la did the fix and now have my door locks back!!!
gotsoot is offline   Reply With Quote
Old June 3rd, 2014, 10:21   #13
indysoto
indysoto's Avatar
Glad it helped...Short procedure worked for restoring my Gf's 2003 passat 1.8t 5spd key functions too!!
Old June 4th, 2014, 12:54   #14
50harleyrider
I just programmed the remote on my B5.5 following battery replacement. Follow directions in the owners manual and don't use the valet key in the ignition when doing it. Put it in the door if you don't have two masters to do the programming. The number of doors activated has nothing to do with the remote. That's set in the module and changed in VCDS. I've also had a remote die along with its battery so watch for that. The manual switch on the passenger doors is a quirk that indeed does work. It must remind the module that there are four doors!
50harleyrider is offline   Reply With Quote
Old October 13th, 2015, 20:30   #15
Big Swole
Big Swole's Avatar
TDI(s): 02 Golf TDI
Fuel Economy: 40 something I'm sure
Subscribed for future ref.
-2016 RAM 4x4 Laramie MegaCab Sport pkg. in Silver
-SOLD - 2002 Silver Golf TDI, 5sp., 116k miles, dynoed 163 WHP, VNT17 turbo, Malone Stg 4, PP764 Injectors, 3bar MAP, SB stg.2 clutch - by AARodriguez
-2006 RAM QCSB 4x4, 1053 RWHP Garmons Diesel built 5.9 Cummins, 10.70 @ 129.4 MPH @ 7100 Lbs. On Diesel Only! (SOLD)
Big Swole is offline   Reply With Quote
Left rear passenger door WON'T unlock... HELP! crashtested VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 27 February 21st, 2016 06:43
Remote wont unlock all doors when pressed twice on remote... GOTLIFT02 TDI 101 4 January 23rd, 2012 03:43
Unlock switches/remote won't unlock rear driver's door MKIInut TDI 101 0 July 15th, 2010 15:33
Doors will not lock or unlock with key or remote drewkeen TDI 101 11 September 15th, 2009 22:14
All Doors unlock \with 1 push of the remote auld OBD Scanners 3 January 12th, 2005 15:40
Page generated in 0.17467 seconds with 10 queries
[Output: 125.52 Kb. compressed to 104.27 Kb. by saving 21.24 Kb. (16.93%)]
