BenzOil
I noticed a new ticking noise the other day in my 04 TDI Jetta PD. Popped the hood and found that the serpentine belt tensioner was bouncing. After some searching here is sounds like it could be the alternator pulley being siezed. Does that sound reasonable? I'm not sure if/when the tensioner was replaced. I'll have to look through the records from the PO. If I replace the Alt. pulley, should I also be looking at replacing the tensioner?
Also is there a good online place for looking up parts and part numbers for VWs?
