Old December 23rd, 2008, 22:54   #1
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
Default How to remove ALH alternator pulley in car
This is a followup to my how to remove an alternator post. If you just need to change the pulley, it can be done with the alternator still in the car, but some special tools are required. You can't buy them (YET), so you will have to make them. Many others have done this, so I cannot take credit for the idea, but I can post pictures to help others who want to do it.
Firstly, you need the spline tool to turn the pulley off the shaft. It is available at Metalnerd.com:
Then you need to buy a seperate 12 point bit to hack up to fit inside the special spline tool. You need a 10mm 12 point or tripple square bit like this:
They are availabe at lots of places. Snap-On will sell you a single bit that you need for around $10. Or, you can buy a set of 4 in different sizes for around $10 at many good tool stores. The one in the pic I believe was from a Lisle set I bought many years ago. The product number for the Lisle set is 60750. Just Google it and you will find many hits of places to buy it.
Once you get one, you need to modify it by grinding away the hex part of the shaft so it fits inside the multi splined tool like this:
I just used a bench grinder. Once you have done that, make sure it fits inside the Other part of the tool. Oh, and don't grind away too much as you will need some of the hex part to hold it with a wrench:
I probably should take some measurements so you can grind the appropriate amount away. I had the luxury of having a spare alternator on my bench to measure. It is important to get the length right as there isn't much clearance in the engine compartment between the pulley and the frame. I had to cut about a 1/2 inch off the end of the bit to get it to fit in:
Now you have made the special tool, you need to get under the car & remove the pulley. Removal of the side splash guard is necessary as well as the serpentine belt, obviously. With a screwdriver, pry off the protective plastic cap off the pulley and you can then insert the tools:
Now, you need 2 wrenches. A 17mm to loosen the pulley and a 1/2" to hold the shaft of the alternator. Since you are holding the shaft & loosening the pulley, you need to turn the 17mm wrench as though you were loosening any bolt or nut.....counter clockwise. I used the frame rail to hold the 1/2" wrench solid while I loosened the pulley with the 17mm wrench by pulling it towards the front of the car:
Instalation is the opposite of removal. In this case, I used the harmonic balancer to hold the 1/2" wrench solid while I tightened the pulley with the 17mm wrench by pulling it towards the back of the car (Clockwise):
Now don't forget to put the dust cap back on the new pulley. Total time to do the swap was about 20 minutes, but it took me 10 minutes to make the tool. SO lets say at least a half hour. More if you need to remove the side skirt as mine was allready off.
I hope this helps many of you who have and or will suffer the very common alternator pulley failure. In may case, there was nothing wrong with my pulley. But I was changing the tensioner as it was bad, so I thought I would change the pulley at the same time as a preventative measure as I have seen MANY of these things fail and I would rather do it in a controled situation in my driveay than on the side of a busy highway in the middle of a snow storm .
Moving? Need boxes?
Go green and check out FROGBOX.com
Old Ride (2000 Black Sedan): Gone
New Ride: (2003 Silver Wagon): Malone Tuned, T4 injectors, 11mm pump, 2.5" Magnaflow cat back, PD150 intake, OMI, Wingnut SS, ERF 6 speed, Bilstein TC Sport susp. w/GTI springs, Neuspeed RSB, Santa Monica's, Autometer Cobalt Boost & EGT, MFA Sport cluster, GLI Leather seats, SS vacuum lines, AVIC Z3 Nav and I still get 4.5L/100km (I got 3.9L/100k on a tank once)
Some handy 'How to's'
Wingnut is offline   Reply With Quote
Old December 23rd, 2008, 23:07   #2
mtbr297
mtbr297's Avatar
Great tip! I had the pulley fall off my wife's car recently and had to pull the alternator.
Steve in Fort Worth, TX
TDI club trusted mechanic.
TechnicalDieselInnovations
mtbr297 is offline   Reply With Quote
Old December 24th, 2008, 08:01   #3
Growler
Got Soot Vendor
Growler's Avatar
Wingnut,
you should add this to the How To Thread in TDI101
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Growler is online now   Reply With Quote
Old December 24th, 2008, 08:38   #4
oldpoopie
oldpoopie's Avatar
Yep. Super easy this way. Ill try and get some measurements of my tool when I get home.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
Old December 24th, 2008, 09:08   #5
philh
philh's Avatar
Fuel Economy: 49/44/37
Great how-to! I wish that Metalnerd would sell the smaller 12-point bit. Fighting that alternator in and out would have saved me about an hour at least.
03 Jetta Wagon GL TDI 5spd Silver 80K Biodiesel
philh is offline   Reply With Quote
Old December 24th, 2008, 09:25   #6
whitedog
Wingnut, you could add a link to this thread and a note to the alternator R&R thread.
Thanks for your work on this.
Old December 24th, 2008, 09:58   #7
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 46 now (2016)
That's fantastic!!! I know I'll be doing mine before too long (hopefully once the winter is done), so I'll have to invest in/fabricate some tools...
Great work, Wingnut!
-Rich
585,500 miles now and counting...14,500 until cluster swap! '00 Jetta GLS, '03 Jetta GL, 08 Highlander, '72 Plymouth Satellite, '68 Chrysler 300, '75 Benz 300D, 78 LeSabre Turbo.
Nutsnbolts is offline   Reply With Quote
Old December 24th, 2008, 10:29   #8
oldpoopie
oldpoopie's Avatar
Wingnut, I tried contacting metalnerd about this a while ago, but didn't get a response. Maybe you could add a poll to this thread to gauge interest. Perhaps the others that have already done this can sing the praises enough that he can be persuaded.
Old December 24th, 2008, 12:46   #9
Wingnut
Wingnut's Avatar
This thread has already been linked in both my Alternator re & re how to and Paramedicks pulley removal how to. So those bases are covered.
And as for a picture of the dimentions of the tool, here is a picture that Bear posted a few months back in Paramedicks how to thread:
I will send a PM to Chuck with a link to this thread. Hopefully he can see the huge benefit to making a tool like this to include with his multi splined tool to remove the pulley. It will cut the time of the swap down considerably and I'm sure there will be a larger market for a kit with this tool rather than his kit with the long 12 point bits.
Moving? Need boxes?
Old December 24th, 2008, 14:13   #10
Growler
Got Soot Vendor
Growler's Avatar
I would rather be able to buy the shorter tool separately..
I already have his alternator kit. just need the shortened 10mm xzn tool
awesome thread.
~Aaron~
Old December 25th, 2008, 00:19   #11
whitedog
awesome thread.
I agree with Aaron. Heck, I haven't even used my alternator tools yet, so just being able to buy the short tool would be awesome. Put me down for one.
I wonder if a Moderator or Administrator could help with establishing a poll in this thread. I know that once a thread is started, you can't add a poll.
Old December 25th, 2008, 11:26   #12
Wingnut
Wingnut's Avatar
It was THIS THREAD from Oldpoopie that inspired me to take some action shots of the procedure in the car. That is why I did this writeup.
This is a nice clean looking tool. The single Lisle 10mm (60780) bit is available for under $4 and if you turn a bunch on a lathe, you could sell them for $15 as a supplement to the Metalnerd tool, for those who already have it.
Moving? Need boxes?
Old December 25th, 2008, 12:11   #13
oldpoopie
oldpoopie's Avatar
the only trouble is that I tore thru many carbide bits when I made mine. These things are hardened and difficult to cut.
Old December 25th, 2008, 14:11   #14
mrGutWrench
mrGutWrench's Avatar
Fuel Economy: 63 MPG/56/47 (2nd tank) '02 Sedab
__. I was wondering about that. Sounds like a lathe/grinder is in order.
__. And, Wingy!!! Another great how-to -- this is going to save a bunch of us a lot of time and trouble.
MrG, Wallace NC (2002 Jetta, Totalled by drunk, 11/'06; 130K mi in 4 1/2 years/~57 MPG lifetime); New car, '03 Jetta Wagon, CAT filter, .681 top gear, 350K mi. in 11 1/2 yr, ~52.
mrGutWrench is offline   Reply With Quote
Old December 25th, 2008, 15:06   #15
philh
philh's Avatar
As would I.
Page generated in 0.20181 seconds with 9 queries
[Output: 134.72 Kb. compressed to 112.45 Kb. by saving 22.27 Kb. (16.53%)]
