My DD, a 1997 Passat started leaking G12 at the water pump in early January, so I parked it outside since it was too cold for repairs, and put my back up plan, yet another 1997 Passat into service, shown here:
With parts, tools, laptop computer and even unseasonably warm weather all in place for my 3 day President's weekend, I got my DD into the garage and did my timing belt and water pump replacement. This was my fourth timing belt R&R and was my second water pump R&R, so I wasn't unfamiliar with the challenge. I had Metalnerd tools (camshaft setting bar, crank lock bracket, injection pump locking pin and the sprocket counter-holding double bar tool) to get the job done.
I used a couple of YouTube videos from Robinsonsauto for the timing belt removal:
https://www.youtube.com/watch?v=5mQ-tA-fSQs
and the timing belt installation:
https://www.youtube.com/watch?v=Sy5ugRg927U
Also, I followed the myturbodiesel procedure for the water pump R&R:
http://www.myturbodiesel.com/wiki/water-pump-replacement-for-mk3-tdi-jetta-and-passat-1z-ahu-engine/
I did order and use the metal/rubber gasket, P/N:026121041P, instead of the paper gasket. Of course, it cost more but made the water pump mount easier since I didn't have to deal with gasket cement while installing 8 bolts. The new water pump installed:
The sprocket counter-hold tool, used on the camshaft sprocket, was also useful for the intermediate shaft pulley:
I would advise buying additional intermediate shaft woodruff keys, P/N: N0127082, before you do this job; these keys vanish into thin air. A large cardboard piece on the ground when you are trying to reinstall the intermediate shaft pulley will make a noise when the pulley key fails to line up and hits the ground. If the key doesn't hit the cardboard, it is hidden on the engine block or elsewhere. It may never be found:
I also used a clothespin to help keep the new timing belt in place on the crankshaft sprocket:
And, I even used a binder clip to hold the timing belt on the injection pump sprocket:
Thanks again to robinsonsauto for uploading the YouTube videos and to the myturbodiesel web site. Here's my repaired DD back in service in the parking lot at work:
