All,
I have a question regarding a problem I have encountered on our 2013 Passat TDI SE. I have wanted to add some Diesel Kleen but the damn silver flap thing in the filler neck will not let me do it. I cannot use a funnel to move the flap either. I even tried to add fuel from a five gallon can, and the nozzle on that will not move the flap either. However using a regular fuel nozzle is no problem.
So what gives? What am I doing wrong or what trick did I miss that has probably been discussed somewhere on the forum to get the flap out of the way. Or did VW design this thing on purpose to keep us from adding an additive or god forbid fuel from a jerry can? I sure hope not because what would you do if you were low on fuel and needed to add some from a can to get to the nearest fuel station? I know that sounds silly, but when you live in the sticks like I do and the nearest diesel pump is 40 miles away, it is something you think about.
Thanks,
Glenn
Thanks,
Glenn
