MITBeta
- Joined
- Feb 24, 2001
- Location
- Boston's Metro South-West
- TDI
- 2001 Jetta TDI, 2004 Sprinter CDI Passenger (Mid/High), former: 1996 Passat TDI Variant
Some of you have probably been following my problems on this thread:
http://forums.tdiclub.com/showthread.php?t=131275
While trying to replace my voltage regulator today it was clear that it was bad:
However the grooves in which the brushes sit looked equally bad, if not worse. One of the wheels appears warped or bent, and there is considerable carbon build-up inside the housing.
After all the work to get the VR cover off and the VR itself out, do I actually just need a whole new alternator? I'm loathe to put the thing back together to find out it doesn't work.
