You did, the link to the thread is in my signature.
I found the wiring to be pretty easy to be honest. The most complicated part for me was the upgrade to the Teves 20 style ABS unit (can't see if your donor has that, but it's a worthy upgrade if you can be bothered) and the immobiliser. I've heard that US-spec B4's never had an immobiliser so you should be ok there and there won't be any issues with the ABS if you decide to retain the original G60 system.
It's simply a case of unplug the Passat engine loom from the fusebox, complete, remove it from the car. Unplug the Corrado loom from the fusebox, remove it from the car, remove the wiper loom and then combine it with the Passat loom, check and rewrap it all. Fit the Passat loom to the Corrado, making sure the necessary wires are back in their existing locations. Swap the fuel pump relay for the glow plug relay. As your car is an early G60 its unlikely to have the OBD2 style diagnostic socket which will be fitted to the Passat - I'd recommend swapping that too to ensure proper diagnostics.
UK cars didn't have a CEL/MIL either so I'm not 100% about that but I reckon it'll just be a case of swapping the complete cluster loom from the Passat to the Corrado. I retained my B4 donor's MFA while doing that; you won't have an MFA on the donor but you should retain the CEL/MIL if everything is plugged in correctly.
Just take your time with it, use your head and a few wiring diagrams and it'll all slot together lovely - I built mine in a little under a month of evenings and weekends so its a very doable conversion.
Read all of G60ING's incredibly informative threads too
HTH.
