richiedan40
Hi guys , ive read up a lot on this one and there is some scary stuff out there , this code has been cropping up for about 15000 miles now.
its intermittent , previous time it popped up the glow light flashes , limp mode and when I restart the engine its fine again , last time it was 6000 miles between faults ! id like to think its not the HPFP or the cam/follower.
this has had a full vw service history and always has European diesel fuel.
its had a fuel pressure sensor on the rail , and in the last 6 months 2 new fuel filters , fitted with prescision and care !
it always occurs when the engine is running between 1200 and 2000 rpm and on very low demand ie driving miss daisy !
since ive had the car its happened 6 times now , and can be a touch dangerous on the freeway/motorway/ autobahn ( country dependant )
through the gears its perfect , pulls like a train. Its also spot on at the top end. one thing I have noticed recently is it jerks a little when pulling off , sounds a bit perverted that ! but no seriously , its a touch hesitant at very low speeds , but not always .
I hope you can help guys , this is now starting to do my fruit in. I,m always a bit reluctant to go to far in case it gives up the ghost.
Please help.
Richie D
ps the car is a 2009 Passat tdi 140 common rail
Please help.
Richie D
