Old June 7th, 2013, 18:17   #1
Tosh2
Default P087/P088 codes
Now that my long running saga of 087/088 trouble codes is close to being resolved, it might be useful to describe the whole story.
Beginning mid September of 2012, at the end of a 800 Km day, I got a flashing glow plug light (GPL) and check engine light (CEL) and limp mode, all of which cleared immediately after re-starting. Over the following 6 months, the problem recurred randomly. Sometimes every two weeks and sometimes every 2 minutes. It was impossible to trigger the fault at will, although it did become gradually more frequent over time.
With guidance from TDI 101 forum threads and the boundless generosity of 2micron, I methodically substituted fuel pressure sensor, fuel pressure solenoid and fuel metering valve. Contrary to all expectations, it was the metering valve at fault and the substitute part has fixed the issue completely.
So away I go the dealer, part in hand, only to be told "not a VW part number, not a VW part - go to Bosch" Is this the ultimate VW brush-off or what? Searching internet sites, I found the part available in Latvia (!) and Spain. The part (Bosch #0928 400 706) is $68 ex Spain, where it's apparently a part common to the Seat brand.
Given the reasonable cost of this part and the 5 minute (including washing hands) of the R&R, it's not a bad place to start if you find a similar problem. Here's a useful description from the Spanish source of how the metering valve works:
The fuel pressure control valve comprises a fuel-cooled solenoid valve.
The valve opening is varied by its solenoid coil being pulse width modulated at a frequency of 1 KHz.
When the pressure control valve is not activated, its internal spring maintains
a fuel pressure of about 100 Bar. When the valve is activated,
the force of the electromagnet aids the spring, reducing the opening of the valve
and so increasing fuel pressure. The fuel pressure control valve also acts as
a mechanical pressure damper, smoothing the high frequency pressure pulses
emanating from the radial piston pump when less than three pistons are activated.
Tosh2 is offline   Reply With Quote
Old June 8th, 2013, 04:25   #2
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Nice post. Could you share with us what trouble codes you had?
Edit: I'm an idiot.. (didn't read title)
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old June 9th, 2013, 15:04   #3
Tosh2
Just P0087 (low fuel pressure) and very occasionally P0088 (high fuel pressure) This is using my hand held OBD giving generic info.
Old June 9th, 2013, 15:24   #4
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
I am an idiot (didn't read title.)
Old May 13th, 2014, 10:16   #5
col m
col m's Avatar
Fuel Economy: 45-63mpg
I have this problem looks like i'm going to try this aswell
I get p0088 high pressure
and two times in ten
p0087 low pressure on the common rail
col m is offline   Reply With Quote
Old May 22nd, 2014, 01:43   #6
col m
col m's Avatar
I fitted the new pressure control regulator ...
which was very easy to do might i add anyone can do it its just two t20 torx this has fixed my car the errors are gone...
happy days!!!
Old May 27th, 2014, 10:49   #7
TDI_Coast2Coast
Fuel Economy: TBA
Did you ever have any instances, during the period you were having issues, where the car would take longer than normal to fire?
If it failed to maintain 100psi when off, could that cause a hard start condition?
- 2010 Jetta SW 6 speed manual / DG SS kit -- Escort 9500ci - Vag-Com(hex+can) -
Snow Methanol Injection - Malone Stage 2
TDI_Coast2Coast is online now   Reply With Quote
Old May 27th, 2014, 13:00   #8
JSWTDI09
JSWTDI09's Avatar
happy days!!!
I fear we might be starting to confuse parts (or maybe I'm just the one confused). There is a fuel pressure regulator valve N216 (on the end of the fuel rail). There is a Pressure Retention Valve (near the back of the engine) that maintains 10 bar (145psi) fuel rail pressure even when the car is off. Plus, there is a Fuel Metering Valve N290 which is on/in the HPFP. I am beginning to get confused about which valve the OP replaced.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old May 27th, 2014, 15:07   #9
TDI_Coast2Coast
Fuel Economy: TBA
Have Fun!
Don
It's not you
I'm a little confused as to what part was replaced...sorry if I added any confusion
The Pressure Retention Valve actually sounds like it could be the culprit for me. I have no issue once started or when it's warmed up. Maybe I'm losing rail pressure after sitting for a long period and it takes a few cranks to build back up? It's very random as well. Is that a part that can intermittently fail? Or is it more likely to just fail completely?
Old May 27th, 2014, 15:20   #10
JSWTDI09
JSWTDI09's Avatar
I believe that there has been at least one failure reported here of that Pressure Retention Valve. The symptoms were mostly as you describe - it starts fine when warm or if it has been off for a relatively short time. However, if left idle for a long time, it takes a while to start. I do not recall how solid (or intermittent) it was, but I am guessing that it could fail either way. I wonder if any of our gurus have seen these fail in their work (they see a lot more of these that I do).
Have Fun!
Don
Old May 27th, 2014, 16:05   #11
JSWTDI09
JSWTDI09's Avatar
It's not you
After carefully re-reading the OP's post and checking out partbase.org, and a few dealer parts websites, I am pretty sure his problem and yours are different. He replaced the Fuel Metering Valve in his HPFP. He is correct that VW does not have a part number for this part, they only want to sell you a whole new HPFP for about $1000. The fuel pressure regulator valve is also not available by itself either, you have to buy the whole fuel rail ($250 mail order to $315 MSRP).
It looks like the part you probably need is (believe it or not) officially called the "Return line pin (male) terminal housing pressure valve" which has a VW part number of 03L 130 235 K (about $82.00 mail order to $103.45 MSRP). It is the return line from the injectors and the pressure retention valve. It is a purely mechanical part with no electrical connection.
Have Fun!
Don
Old May 27th, 2014, 16:54   #12
TDI_Coast2Coast
Fuel Economy: TBA
Have Fun!
Don
Thanks for your help...At least the two possible faulty parts are not too ridiculous. Fortunately I haven't really had any issues with the car, so I haven't educated myself enough on it. I have issues with remembering the names of parts I'm becoming my Dad and calling everything a "whatchamacallit"
Old July 16th, 2014, 14:00   #13
actnbill
Do you remember where you found the Bosch part ?? I'm looking for the same part and can't find it anywhere for $65......only about $200 so far...
Bill
actnbill is offline   Reply With Quote
Old July 16th, 2014, 16:53   #14
Rock77
Rock77's Avatar
TDI(s): 09 Jetta
I too am having a difficult time finding the part.
2009 Jetta Tdi Highline 6m
2003 GMC Sierra 2500HD 6.6 DuraMax
2004 WRX, project car
Rock77 is offline   Reply With Quote
Old July 26th, 2014, 08:28   #15
actnbill
I just located the Bosch sensor on eBay. I did a search for Bosch 0928 400 706 and saved the search on ebay to send me an email when that item got listed by someone....
It's a used part for $60 from an auto recycler's 2011 Jetta TDi, but that's a lot better than paying $225 plus shipping from europe.....
I'll post how it works when I get it installed....
Help with codes adamant628 TDI 101 8 March 30th, 2010 10:36
Vag-com Codes? I Have 6 Engine Codes, What Do They Mean? nosshane TDI 101 3 July 21st, 2007 12:34
?? codes D. Reed VW MKV-A5 Golf/Jettas 1 November 21st, 2006 14:07
Handheld OBD that reads codes & can reset codes? amishman OBD Scanners 5 December 28th, 2004 13:36
Codes....HELP !! Jetta4Me General Automotive 1 September 3rd, 2004 02:55
Page generated in 0.15852 seconds with 10 queries
[Output: 135.22 Kb. compressed to 113.34 Kb. by saving 21.88 Kb. (16.18%)]
