WinterPhoenix
My check engine light came on in my 2000 New Beetle last weekend. I was driving on the interstate when the light came on. Since I didn't notice anything immediately wrong with the car, I decided to push on for a while. When I stopped for a bathroom break, I decided I should go to AutoZone for their free check engine light diagnosis.
My car is returning the code P1557. Here's the information I got from AutoZone on the code:
Definition: Charge pressure positive deviation
Explanation: External leak on intake or exhaust side
Probable cause 1: Failed charge Air pressure sensor
Probable cause 2: Failed wastegate regulator valve
Probable cause 3: Failed turbocharger
Since getting to my destination was critical and all the driving would be on the interstate, I decided to push on and try to avoid pressuring my turbo system. The car successfully completed the drive.
The other night I had to drive down the street to get some groceries. On the way there, the light came on after diagnostics completed (as expected). On the way back, however, the light came on and then went back off. Is this normal? I feel that this might be more indicative of a loose hose or valve (the wastegate regulator?) since it sometimes passed diagnostic checks.
Thanks in advance,
Winter Phoenix
Thanks in advance,
Winter Phoenix
