If you are just looking for opinions and not for what is technically correct, you can probably be OK using non synth 15W40 Delvac, Delo, Rotella or the more recent one that Castrol has out, in an ALH engine, provided... a)The temperatures do not go below freezing, (If your oil is too viscous from the cold, it won't get up into your turbo bearings in time) b) before you shut down your engine you let it idle for about 30 seconds to cool off any hot spots on your turbo's bearings (The hotspots can be so hot they can turn the static conventional oil to something akin to asphalt and this will destroy your turbo bearings - called coking your turbo), and c) you change it every 5000 miles. I believe conventional oil was permitted in the early ALH's but because of the above issues, the requirement was changed to synth only. I actually think that the ALH block and head has no problems with conventional oil. The considerations are mainly for the turbo. Would I use conventional oil in my ALH? In an emergency I would, but otherwise I see no reason to. Again, this is just my opinion.
