| Fuels & Lubricants Discussion all about Fuels & Lubricants. synthetic oil, conventional oil, brands, change intervals, diesel grades, gelling and such debated items like that. Non TDI related postings will be moved or removed. This forum is NOT for the discussion of biodiesel and other alternative fuels. |
November 17th, 2006, 21:36
#1
Moderator at Large
"What oil do I use?" READ FIRST BEFORE ASKING
Lately, there have been countless threads asking again and again, "What oil should I use". Please don't ask it again! Read this first. For what it's worth, there is not much here which is not in your owner's manual, but somehow nobody ever seems to read those ...
This question has to be answered in three parts, because there are three different "families" of VW TDI engines. The critical factor is whether your engine uses the older "rotary distributor pump" mechanical injection system, or the "pumpe-duse" or short-form "P-D" fuel injection system, or the new for 2009 "common-rail" fuel injection system. If you don't know, and you are in North America, it's easy to figure out: all TDI engines 2009 and later are "common-rail", all TDI engines sold here for 2004 through 2008 model years are "pumpe-duse", and all TDI engines sold here for 2003 and prior model years are not (they are "distributor pump"). There were no 2007 or 2008 Jetta TDI's but I am including those years in the list to make allowance for the Touareg. The Touareg's V10 is P-D no matter what model year.
If you are elsewhere in the world, it's more complicated because the P-D engines were phased in starting in 2000 and the common-rail engines were phased in starting in 2008 for VW-brand vehicles (Audi started earlier). If your 4-cylinder engine had an original horsepower rating of 90 or 110 then it is "distributor pump". If it was 100, 115, 130, 140 (*), 150, or 170 (*), then it is "pumpe-duse" (or in the case of (*) it could be common-rail). If it is 2.0 litre displacement rather than 1.9, then it is "pumpe-duse" or (*) common-rail regardless of power level. You can also tell the "distributor-pump" engine by the external injector pump driven by the timing belt on the front of the engine.
If you still cannot figure it out then assume it is a P-D. The oils suitable for a P-D are also suitable for the older models. The reverse is NOT true.
Okay, with that out of the way, here goes.
PART ONE: For engines that are NOT "pumpe-duse" or "common-rail". This is for the older-design mechanical rotary distributor pump engines.
You must use a synthetic engine oil, recommended viscosity 5w40 although 0w40 is also permissible (and in the case that the oil meets specifically one of the VW 505.xx standards then the viscosity does not matter, it could be different), AND in the fine print on the bottle that lists what standards that the oil conforms to, it must list either VW 505.00, ACEA B3, ACEA B4, API CJ-4, CI-4, API CH-4, or API CG-4. (Note: "Either" means ANY ONE OF, not necessarily all of them. For example, if it's VW 505.00 but doesn't list the others, that's fine, because VW 505.00 is "one" of the standards listed and you only need "one".) But do NOT assume that any synthetic oil will meet these standards. READ THE BOTTLE. For example, most versions of Mobil 1 do NOT meet these standards (they are meant for gasoline engines). Also, any oil that is suitable for a P-D is fine for a distributor-pump engine.
Many "European car" synthetic oils meet these requirements. So does Mobil Delvac 1 5w40, Shell Rotella Synthetic 5w40 or 0w40, PetroCanada Duron Synthetic 5w40 (can be special ordered at any PetroCanada OilChangers location in Canada), Castrol Syntec 5w40 European-car formulation, and quite a few others. IF IN DOUBT, READ THE LABEL.
The VW part number for the oil most commonly used at the dealers is ZVW-352-540S = Castrol Syntec 5W-40 (VW 505.00 rated, suitable for non-PD TDI engines; not suitable for PD TDI engines). If they use the PD oil (see below) that's OK.
PART TWO: "Pumpe-duse" engines.
VW requires that you must use an engine oil that explicitly states that it conforms to VW 505.01 (and in some cases oils that meet 506.01 or 507.00 but which also cover the 505.01 specification). NOTHING ELSE. Common choices are Castrol 5w40 TXT 505.01 (do NOT confuse this with the regular European-car formulation of Syntec 5w40, it is not the same), Elf Excellium VW 505.01 (has since been renamed to a Total brand), Motul 6100 VW 505.01, Motul Specific 505.01, and there are others. ALL such oils prominently state VW 505.01 printed on the bottle. If it doesn't have that, it is NOT ACCEPTABLE.
Explanatory note: Lately, a number of folks have been doing their research, and have been getting good oil-analysis results with a number of very carefully chosen oils that are not "officially" approved by VW. Mobil 1 TDT (Turbo Diesel Truck) CJ-4 is one of them, and this one is fairly readily available. This will of course not help you if you try to make a warranty claim. If it's under warranty, see paragraph above if you want VW to even consider covering it.
The VW part number for the oil most commonly used is G-052-167-A2 = Castrol TXT 505.01 (VW 505.01 rated, suitable for PD TDI engines; also VW 505.00 rated and suitable for non-PD TDI engines).
PART THREE: "Common-rail" engines.
You must use an engine oil that explicitly states that it conforms to VW 507.00. NOTHING ELSE. These engines are too new for anyone to have experimented long-term with substitutes ... and in this case, the effect on the emission control components has to be considered. The VW part number for what is normally used at the dealer is GVW-052-195-M2.
Due to the limited number of VW diesels in North America, these oils are typically available only at VW dealers and parts vendors that specialize in VW cars. Other parts vendors might be able to special order it, so ask. To forestall another question, this is NOT a "monopoly". Engine oil vendors outside of VW dealers are perfectly free to market oils that meet VW's standards. The fact that not many have chosen to do so is THEIR fault, not VW's.
Beware the "meets or exceeds" game. The oil has to be certified to these standards by VW themselves. Amsoil is one notable oil brand which does not pay for such certification. They produce an oil which states VW 505.01 on the bottle, but it is not on VW's list of certified oils. That doesn't mean it's a bad product ... it just means that if something bad happens, there is a possibility that VW isn't going to warranty it (on the grounds that you did not use one of VW's certified oils), and if that happens, you are going to have a battle on your hands. It is BEYOND THE SCOPE OF THIS THREAD to explore the fine points of VW 505.01 certification, the subject has been beaten to death elsewhere with no end in sight, this thread merely serves to make you aware of the situation. If you want to research this, search the forums - there is already a ton of discussion on this and I'm not going to tolerate any further discussion of it in this thread.
WHAT HAPPENS IF I USE SOMETHING ELSE?
If the oil is not meant for diesel engines, it won't survive the high-soot environment. Oil meant for diesel engines is formulated to deal with the soot.
If you use a non-synthetic oil, it doesn't withstand high temperatures as well as synthetic oil. There are two areas of concern, the turbocharger, and the upper piston rings. There have been cases reported where upper piston rings were sticking due to oil breakdown, causing high piston ring and cylinder wall wear. There have been cases where turbochargers coked up their oil feed line and grenaded as a result.
If you use an oil that doesn't meet VW 505.01 in a P-D, expect high camshaft and lifter wear in the long term. MOBIL 1 (Gasoline engine oil) IS NOT GOOD ENOUGH. (Some people have been reporting good oil-analysis results using Mobil 1 TDT even though it doesn't carry the VW approval.) These engines have unusually high contact pressures between the camshaft and lifters due to the narrow cam lobes forced by the space taken up by the P-D injector mechanism. It is NOT a safe assumption that an oil suitable for large truck engines which also have unit injectors will work in a VW P-D TDI.
If you use an oil that doesn't meet VW 507.00 in a common-rail engine, there is a risk that the additive package in the oil will be incompatible with the (very expensive) emission control system - and it's not only the emission control system at risk. These engines deliberately squirt an extra shot of fuel into the cylinder on the exhaust stroke to heat up the catalytic converter in order to "regenerate". A portion of this fuel will end up on the cylinder walls, be scraped up by the piston rings, and end up in the crankcase, where it will dilute the engine oil. The engine oil must be designed to tolerate a certain amount of fuel dilution on these engines.
Brian P.
2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear, and a roadrace bike on the trailer
November 20th, 2006, 07:17
#2
Moderator at Large
I am going to do everything I can to keep this thread relevant. If there are any off-post discussions or arguments, those posts are history, so don't even think about it. If someone posts a correction that is valid I'll either leave the post there or edit the original post if that post was in error.
Brian P.
November 20th, 2006, 12:39
#3
Moderator at Large
I want to leave this thread open. If someone wants to post in this thread about BIG easy-to-find places where one can obtain various 505.01, 506.01, 507.00 oils in particular (e.g. on-line stores or vendors, large retail chains, etc) then I'm OK with that. (But we don't need to hear about the tiny retail outlet in Williams Lake BC, or wherever you happen to live, that happens to have one bottle on the shelf, because knowing that doesn't do any good to 99.99% of the people reading this.)
AndyH is easy to find, and a supporter of these forums, if you want to buy Amsoil on-line in the USA :-)
If you are in Canada, and you want to mail-order Elf oil, here's one place http://www.h2sport.com/products.php?productid=206 and here's a place that sells several different brands http://www.precisiontuning.ca/catalo...x.php?cPath=43 BUT make sure you read the specification charts before you pick what you want. (For example, Elf excellium DID is suitable for P-D and Elf excellium LDX is not.)
Brian P.
November 29th, 2006, 04:03
#4
Disclosure added by GoFaster: TwoSlick is an Amsoil dealer.
The bottom line is this: Regardless of whether an oil is on VW/Audi's "Approved List", the oil formulator is ultimately responsible for the quality of their product. If they were to blend a batch of defective oil and had a rash of engine failures as a result, it would not matter if the oil had been on the Approved List since day one. This idea that using an approved oil provides some sort of legal cover is simply not valid and any lawyer will tell you that.
Furthermore, this idea of a couple of random, oil related failures from using Amsoil (or any other VW 505.01 labelled synthetic), is simply not a plausible scenerio. If Amsoils' 5w-40, VW 505.01/VW 502.00 oil did not work in the VW PD application or in VW/Audi gas engines, you would not have the occasional failure, you'd have hundreds if not thousands of engine failures and it would be very obvious.
I've been selling Amsoil for VW/Audi applications since 1980 and have yet to have a dealer balk at using their products, or run into any liability issues with them. In fact, I take in five qts of Amsoil every 10k miles, for the local Audi dealer (Jeff Sikes), to install in my 2002 Audi TT roadster, which is covered by Audi's free maintenance program for the first 50,000 miles/4 yrs. The dealer provides the OEM filter and labor for free under this program and they would provide the oil for free as well, if I cared to use their Group III based, 5w-40 Castrol synthetic
December 10th, 2006, 13:45
#5
Moderator at Large
Thread Cleanup
Okay folks, the intent of this thread is NOT to have the never-ending Amsoil discussion (it will continue elsewhere), but rather to give newbies informantion on where to purchase oils that meet their car's requirements, to the best of our abilities to interpret that.
All of the bantering has not changed my view of the validity of the original post. In my view, the point concerning "approved and certified and on VW's official list" versus "meets or exceeds" needs to remain in there but it needs to be CONCISE, not spread out over three pages. I think the original post adequately addresses this, but if someone wants to make a better suggestion of how to do this (50 WORDS OR LESS) fire away below. If I like your wording in place of mine, I'll include it.
I am NOT going to entertain completely avoiding the issue (Sorry Amsoil proponents) but I also don't want to scare people away unnecessarily. The situation "is what it is", Amsoil says it meets 505.01 but it's not on VW's official approved list. THAT'S THE TRUTH as far as I know it, and the interpretation of that HAS NOT BEEN DECIDED IN A COURT OF LAW.
I've done a major clean-up on this thread, leaving only posts that include relevant discussion, and I've edited those to only include the heart of the matter. I have left in a VERY small number of selected posts which illustrate the views of Amsoil vendors and counterpoints to those views, but THAT'S IT for the Amsoil wars in this thread. They are DONE. Have the discussion elsewhere. If the newbies that this thread is aimed at are sufficiently interested, they are free to search the forums.
I am NOT going to tolerate any "pros and cons" discussion of ANY given product. It will be deleted without question and without discussion. The only stuff I won't delete from now on are constructive posts, on the order of "If you want to purchase product X, then place Y sells the stuff."
Brian P.
December 11th, 2006, 00:18
#6
Disclosure added by GoFaster: BleachedBora sells products of various brands, some of which are discussed in this thread.
I carry 505.01 and 506.01. I can also special order any ELF oil including 507.00. Please see this thread:
http://forums.tdiclub.com/showthread.php?t=152185
Thanks for the information Brian, great job!
-BB
December 13th, 2006, 10:17
#7
1. VWAG has created and defined the VW505.01 standard.
2. VW505.01 candidate oils are submitted to VWAG for testing.
3. Candidate oils that pass are certified by VWAG as VW505.01
4. VWAG, requires as a precondition for warranty coverage, the use of VW505.01 in the PD motor.
5. VWOA has issued a number of TSB's, sticker warnings, web postings, papers and pamphlets emphasizing and alerting owners to the requirement and listing a number of products that have been certified by VWAG and ARE VW505.01.
6. Neither defining VW505.01 nor specifying VW505.01 violate any of the provisions of Moss - Magnuson or the Sherman Act regulating tie-in-sales.
That's a concise outline of the facts. Looking at that it's hard to understand why anyone would question the clear linear logic or the undeniable intent of VW with the VW505.01 standard.
But, there are those who have a strong financial incentive to cast doubt and search constantly for loopholes.
A persistent one seems to be to say that, "Any bottle, from any source, sold anywhere, that has 505.01 printed on it is good enough".
A handful of selected UOA's have absolutely no bearing or relevancy on that argument. That reasoning requires that all bottles with the magic number printed on them be treated and accepted equally and without discrimination.
If the FAQ is meant to be a resource for newbie’s, and if it is meant to reflect the collective wisdom and experience of the community as a whole...
Then I suggest that it is wrong and a disservice to those seeking help to include any PD oil advice that can not be supported or that is capable of causing harm to the uninitiated reader.
I think the general thrust now, that 'VW505.01 Alternatives' be given it's own paragraph and be clearly labeled as just that, "Alternatives to Certified VW505.01" with ample caveats and links to the controversial nature of the subject is the only honest way in which a document bearing the "Fred's TDI" name should be presented. To do otherwise is to either lend commercial support to a specific product or to leave newbie’s hung out to dry either putting real crap in their motors or as now, starting from scratch in an attempt to reinvent the wheel and decipher unknown oil standards and legal minefields.
This should remain a neutral community striving to share and understand and not a replica of Washington, DC, where commercial lobbyists through perseverance, access and force of will are able to water down, stretch and redefine everything until it enriches them and ultimately loses any and all value it may have had for the common man on the street.
December 13th, 2006, 13:23
#8
Originally Posted by jombl
Nothing can supercede the mountain of VW clear and obvious intent, except an offical document.
Indeed - especially when it IS an official document.
For an indication of who runs the US warranty, and what hardware (read: cars) they cover and don't cover:
Double check YOUR books for YOUR car. These pages are my MY 1997. I confirmed the portions in RED with VWoA in late 2006.
December 13th, 2006, 16:12
#9
Originally Posted by Bob_Fout
So VWoA has Amsoil on their list of approved oils? Will it be listed in the next iteration?
This isn't about any oil. This isn't about any oil company. This is about VWoA's view of the approved list, and products allowable for use under warranty - and nothing more.
Sorry, Bob - I'm frustrated and am having a real challenge communicating this point clearly.
I spoke with the guy at VWoA that's responsible for new product introductions - including what oil specs to link warranty to. He called ME. He knows I'm an AMSOIL dealer. He knows AMSOIL products are not to be found on the approved lists. With that as a background, we talked about the wording you see above in the owners and warranty manuals - the parts in red.
The point isn't about oil or chemistry or brand or from which country it comes - it's simply what VWoA requires of owners for warranty support.
I just don't know how to make it any more clear than that. Since I am seen having obvious bias, I have freely given the info and contact details to all that have asked and requested they verify what I've written with VWoA.
December 13th, 2006, 17:06
#10
Originally Posted by AndyH
Fantastic! Yes - other specs are allowed for 2003 and earlier cars - as are other viscosities. Info from my '97 is posted above. In some model year, the temperature chart stopped showing up in the owners manual but remained in the service manual.
Can you scan your owners manual and/or service manual for your '02 and '05?
From my 2005 - Engine Sticker plus OM pages. No viscosity chart.
2002 Golf GLS TDI
December 14th, 2006, 12:34
#12
Oil Wanker
Supposedly Amsoil will foot the bill for damage if the correct oil was used correctly and damage still occurred.
December 14th, 2006, 12:42
#13
True, Amsoil will repair any motor that was damaged by a defective batch of oil.
It is possible for a consumer to be caught between Amsoil's insurers, who may deny a claim because the Oil was not shown to be defective and VW which denies the claim because a non-VW505.01 oil was used.
Experimental use of a non-VW505.01 Oil during the warranty period is beyond the scope of an FAQ for newbies.
December 14th, 2006, 13:43
#14
Fuel Economy: avg. 41.93 high 46.32 low 34.6
We would like to keep this thread open so the discussion can continue. Twisiting stuff all up will accomplish nothing. I have a statement from LIqui Moly which says the same thing all the rest have said. Which common sense says if you have been in many American courts. I contacted Liqui Moly because they are in Germany and close to VW. I also knew the had no stake in Amsoil. They also have 505.01 oils not currently on the list as well they have several that are. I will cut and paste, his English is rough but understandable.
If you have a damage inside the engine and oil is not the reason, so you don´t loose the warranty. If oil is the reason for a damage during the warranty, so our company has to pay and if oil is not the reason of a damage, so Volkswagen has to pay the warranty.
With best regards from good old Germany!
Maschinenbautechniker / Technical Engineer
Abt.: F&E/Anwendungstechnik / Application Engineering
Liqui Moly GmbH
Jerg-Wieland-Str. 4
D-89081 Ulm-Lehr
VW would have to prove the oil was the cause of the failure, if they did Amsoil would pay this claim. VW would have to show this oil to not be suitable. If you approach this question to any of the oil makers they all respond similar.
December 15th, 2006, 08:28
#15
Moderator at Large
Once AGAIN, I have gone through and done a lot of clean-up. I kept the pictures posted of the owner's manuals and the warnings under the hood. I kept the link to VW's list of certified oils list. And I kept the part about the oil manufacturer being responsible for damages to the engine caused under warranty. I have not made up my mind yet about the above two posts. I'm leaning towards deleting both.
Brian P.
