Hi All,
I am new to the forum and could use some suggestions regarding my 2006 Jetta TDI. I had an issue with the camshaft at ~58K and it was replaced at the dealer since it was still under warranty. I am now at ~107K and have been having similar symptoms for a while (hoped it was a fuel filter or the glow plugs instead) so my husband and I took off the valve cover and discovered it looks like it is time for a new camshaft again.
Seeing as my tires shouldn't last longer than my camshaft I have reach a point where I think the OEM design or the metal used could be the problem and I am starting to look at alternatives so that I can keep the car and get it running properly again.
Any thoughts on what the best alternative camshaft is?
Debating trying this but not sure it is is worth it
http://www.kermatdi.com/servlet/Detail?category=Colt+Cams&no=8220¶m_referer=http%3A%2F%2Fwww.kermatdi.com%2Fservlet%2FCategories%3Fcategory%3DColt%2BCams&searchpath=19013569
How many others have had a similar problems?
I mainly ask because I spoke to the dealer and VW directly and they claimed it was only me but I think they are full of it.
I have pictures showing the damage that I can share if need be.
Thank you all in advance for your help and feedback.
