Closed Thread
Old August 13th, 2011, 08:12   #1
Franko6
Default No Drill PD Cam Bearing Mod
About two years ago, we introduced a modification to the PD cam bearings that markedly improves oil flow for the cam bearings and the journals for the PD engine. (see Reengineering PD cam bearings, http://forums.tdiclub.com/showthread...=reengineering )
Besides improving oil flow to the journals, the additional benefit is that the oil is ejected from the top bearing shell is doubled. That increased oil flow improves cooling of the cam followers. We feel this is the one of two major reasons for cam/ cam follower failure.
We recommend using these modified cam bearing shells with our reprofiled Stage II cams with chrome-plated journals.
The method was to modify the top bearing shell with a radial slot. then change the oiling by drilling a path to the rocker shaft galley hole.
However, the drilling leaves many DIY'ers uncomfortable about the possibility of broken bits, chips in the oil galley, and the chance of causing a big delay in what should be a one-day project. Some are squeamish about drilling a very small hole that is in some cases, an inch deep. If I perform the alterations to the caps, it can cost a week of down-time in mailing delays.
The solution:
NO-DRILL CAM BEARINGS!
This is our original bearing slot for the top bearing. This allows oiling as in typical for crankshaft top journal bearings. Oil is full penetration on the non-loaded bearing, which improves oil flow and oil wedging to the pressure-loaded bottom bearing.
This is the slot in the outside of the shell, allowing oil to come from the original oil galley hole, directly to the top bearing shell. Please note, this is before the outside shell has been deburred.
Placement is done as follows:
After the cam is removed, mark the cam bearings as follows. The #1 bearing and #5 bearings are marked on the internal side. # 2, 3 and 4 can be marked no both sides This is done for location purposes, because the tang is removed on the bottom bearing shell to allow the shell to be reversed.
Remove the original bearings and assemble the new bearings as marked. This shows the #1 bearing and slot. Note arrow pointing to front of engine.
Align bearings between the marks and press into place. That's IT!
Top shells with slot are installed the same direction as OEM using the tang.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Franko6tdi@gmail.com
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Last edited by BKmetz; August 29th, 2011 at 03:50. Reason: put spaces between the photos for easier viewing
Franko6 is offline
Old August 13th, 2011, 08:26   #2
Franko6
Default PD Reprofiled Stage II Chrome-Plated Cams
We have our own reprofiled, chrome-plated Stage II cams in stock. We can ship with all reassembly parts. Our pricing can be with or without the chrome-plating, but we seriously feel that the plating is a big improvement in performance and wear resistance.
WE WILL WARRANT OUR CAMS FOR THREE YEARS, UNLIMITED MILES
To qualify for warranty, each kit must be 'complete', which means each kit will include the choice of chrome-plated cam with the BRM or BEW/BHW injector profile, our modified cam bearings must be properly installed, new nitrided INA lifters, PTFE cam seal, tandem pump seal. We will also mandate our break-in procedure and Joe Gibbs break-in oil. The customer will be required to document use of a VW/Audi designated 505.01 oil that is a 5-40 weight. Our preferred brand is Schaeffer's 9000 5-40, however we will accept other products, as long as they meet the proper ratings. If you are not sure if your oil would qualify, please check with us.
We will not warrant damages arising from abuse or neglect.
The chrome-plating is not like what you see all shiny on you old Cadillac bumpers, but is referred to as hard-chrome, or hexane chrome. The hardness layer increases the journal hardness to Rockwell 72-74. There is only a slight color-shift from the forged steel of the injector lobes and the chrome-plating of the cam journals. This is a performance modification with a well-established benefit. It reduces parasitic horsepower loss, while improving bearing life through reduced friction and excellent heat transfer properties. Also, oil flows through the bearings with less resistance on a smoother finish.
This hexane chrome coating along with the use of our 'no drill' cam bearings doubles the flow of oil through the bearings to the cam followers. Elimination of the cam follower oil starvation is the main purpose of the cam bearing modifications. The secondary purpose is to help overcome an inherent engineering problem of the bottom journal bearing. The lack of bearing support lends it to premature wear. The cam and bearing mods will create improvement in bearing performance.
Chrome-plated BEW/BHW cam..........$695.
Chrome-plated BRM cam....................$725.
Email or PM for kit pricing
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Franko6 is offline
Old August 13th, 2011, 08:44   #3
dieselpower04
dieselpower04's Avatar
Price on these? HP and ft-lb increase?
Gone but never forgotten...
My TDI Build Thread
dieselpower04 is offline
Old August 13th, 2011, 09:15   #4
OlyTDI
TDI(s): '04 Golf
Frank,
Glad to see the launch. Some questions:
What do you project availability to be?
How quickly could someone get one of these in a pinch?
How would a current "mild" PD tune interact with this swap, i,e., would a tune tweek likely be needed?
Lastly, cost as mentioned above?
Thanks! Glad to see this!
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline
Old August 13th, 2011, 09:28   #5
OlyTDI
TDI(s): '04 Golf
Frank,
Can these be used with existing stock cams that have not yet bit the dust or should they only be installed with a new cam?
Thanks!
2004 Golf GL PD TDI
OlyTDI is offline
Old August 13th, 2011, 13:49   #6
Franko6
The oiling mod would help with a stock cam also.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Franko6 is offline
Old August 13th, 2011, 14:12   #7
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Eddif in 3...2....1...
Proudly installing things where they're not supposed to go since 1996!
Windex is offline
Old August 13th, 2011, 14:17   #8
Franko6
These cams are in stock and ready to ship. We have about 25 in stock right now and have our producer on schedule for more on a regular basis.
We have been quietly selling these for months. I did want to get some measurable feedback before hitting the streets. They are exceeding expectations.
The cam does not require a chip tune, however we have seen some interesting findings. Rather than having to reduce fueling due to overboost as in some other cams, the profile seem to be able to handle additional fueling without issue.
I can only assume that reduced fueling to compensate for the boost creep in a tune interferes with the production of power. I'm not sure if this is due to our attention given the torsion value or if the profile is simply better. Time will tell.
As for pricing, the base cams recently had an increase in pricing. We had been selling the cam for $650. However, that is now the current pricing for a non-chrome-plated journal version, which we are not aggressively marketing. The Chrome-plated version is currently set at $685.
Chrome-plating adds hardness to the journal. It is a scuff-resistant material that wears better than steel and polishes to a higher luster. The smoother, the better.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Franko6 is offline
Old August 13th, 2011, 14:27   #9
Franko6
We have improved results matching up with another Stage II cam. Torque starts quite early; around 1800 rpm.
We will have dynos for a stock profile cam that is in good condition compared to a reprofiled cam shortly. It wouldn't be fair to compare a worn-out stock cam than it would be fair to use Stage II results for a Stage I cam. That would only make exaggerated results. Results will be based on a stock tune. We will try to get some Stage II chip-tune comparisons also.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Franko6 is offline
Old August 13th, 2011, 14:38   #10
Growler
Got Soot Vendor
Growler's Avatar
I just finished installing one of these cams for the first time.
the cam went in perfectly, Franks Modified Cam Bearings worked great. no drilling of cam caps, or drilling into the cylinder head required. it is obvious that the oil will now get to where it is needed most, the dwell side of the cam so it has time to form the film it needs to support the cam.
Customer left here about a half an hour ago with miles of smiles on his face.
Frank, Thanks for all that you do.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Growler is offline
Old August 13th, 2011, 14:45   #11
Growler
Got Soot Vendor
Growler's Avatar
I just installed a set of these. if you look closely at where the bottom bearing used to be, you can tell where they used to sit on the supports. there will be a line on the aluminum where the edge of the old shell was located. makes reinstallation a breeze. Pay close attention to the #1 bottom bearing. it is not against the inside edge as you would expect.
Frank, Very Good mod. well worth not having to drill holes into the caps or the cylinder head.
~Aaron~
Growler is offline
Old August 13th, 2011, 17:23   #12
Honeydew
Wow, a buyer would be nuts not to get the hard chrome option for $35!
Honeydew is offline
Old August 13th, 2011, 17:24   #13
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
A bit OT I know, but any word on a similar cam for the VE TDIs?
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline
Old August 17th, 2011, 16:37   #14
Franko6
Thank you Aaron (Growler). These will probably get another improvement of an alternate tang placed into the bearing. It depends on how well that can be performed. With a bearing like this, neatness counts!
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Franko6 is offline
Old August 17th, 2011, 16:40   #15
Franko6
Bob, the question of plating the ALH and AHU cams was brought up at Monday's meeting. The cam journals can be plated, even on those cast cams. The question is whether it is worth doing. Plating costs more than $35, believe me. Compared to the price of the cam for the VE motors, the chrome-plating is prohibitive.
Honeydew, the pricing of the cam is subject to review. Our pricing is subject service and materials price changes.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Franko6 is offline
Closed Thread
Colt Cams Stage 2 Upgrade on PD Motor (before and after dyno) OmegaRenegade TDI Power Enhancements 66 September 21st, 2016 07:51
Cheap PD cams and Good PD cams... both available at kermaTDI VailPowder Vendor & GroupBuy items for sale 15 May 29th, 2011 10:41
New Colt Cams 5.9L Cummins Big Stick Stage 3 Cams at kermaTDI VailPowder Vendor & GroupBuy items for sale 5 May 17th, 2011 11:44
Advice on RC Stage II on TDI-PD mdcclxxvi TDI Power Enhancements 23 October 23rd, 2006 05:39
Page generated in 0.16405 seconds with 10 queries
[Output: 132.74 Kb. compressed to 111.05 Kb. by saving 21.68 Kb. (16.33%)]
