DougInFL
- Joined
- Aug 20, 2011
- Location
- New Port Richey, FL
- TDI
- 2001 Jetta 5-speed (Greasecar), 2002 Jetta TDI wagon auto, 2003 F350 7.3 CC LWB (soon to be Greasetruck)
2001 ALH, 5-speed, 244K
The problem is first start up of the day it runs like crap...shaking like running on 2-cylinders. VCDS readings cold are 1.81, 1.88, -1.86, -1.88.
She puffs alot of smoke.
Thought the initial problem was the 205 nozzles that might have been plugged, so installed a set of 357 nozzles that I ultra-sonic cleaned prior to install. Same issue with lots of smoke and rough idle.
After I let it idle for 5-7 minutes, it smooths out and the VCDS readings are .19, 1.88, -1.36, -.73
When reading the posts here, I decided to swap the crank sensor from my wifes 2002 TDI. No change.
Other info: It can sit for about 1/2 hr after running for 5-10 miles, and after restarting it's running rough for a minute or two....slightly reving the engine it clears back up and runs smooth.
When the engine is warning up, i see on VCDS that the temp is climing to normal temp. Is there another temp (or coolant) sensor that could cause this issue?
Footnote: When the car is running smooth, she runs like a scalded dog....fast and furious.
Another thing I may mention is when it's running smooth at idle, VCDS shows 2.2-2.6 mg/str , .30 liter/hr
One other thing I tested was looking for an air/vacuum leak on the return fuel line just prior to the 'T' at filter. Had to pump the miti-vac to 27/in. prior to fuel would start flowing.....minimal bubbles. Filter is new.
Any feedback would be great......Thanks in advance....
