robnitro
Something is wrong... maybe a slight boost leak? Stock housing 17 psi (1.2bar) should be MAX 1080 or so. Check another TDI....
That might also be why your turbo is making funky noises. A boost leak is dangerous, you shift the map to the right, same PR ratio (up down on the comp map) but to the right, makes it overspeed etc.
I like the map based limiter! So far so good, similar results to maf. If I pop off a hose, I won't get smoke, lol....
Similar fueling... I set 2700 to 52 mg/s and I was hitting 51mg/s with 2650mbar. Smoky with 11mm and the titan 764. Idle IQ at stock setting hammered to 4 @ 1.56v (to match the pump map exactly). To get rid of the smoke, adapted to 32688, a reading of 6.6. So my fueling was cut down 2.6 to be smokeless at WOT.
51-2.6=48.4 which is about what I was smokeless when the MAF columns were limiting me. To find out what my injectors+pump really does, I take my maf readings of 1275 around the midrange when boost is 2650mbar. Divide by 16.5 afr, and I get 77mg/s... which my tune says 48.4. 77/48.4= 1.59x!
Makes sense, stock pump, stock injectors can do 51 max. The guy who did the pump voltage map did the last column at 65, but on .230 injectors. So it balances out.
I think I might want to do what bhodgkiss posted, his pump map goes to 80... maybe that's better calibrated for my setup.
BTW, why do so many tune to only 4500-5000 rpm? Our ALH 11 and 10mm rotaries can make flat hp until 5500 easily... scale back the fueling, ex 51mg at 4000 gives same hp as 5500 with 37mg/s!
