Old March 17th, 2008, 17:40   #1
Satiro
Satiro's Avatar
Default MAP sensor MOD...
I'm very interested in make this mod and i believe that a lot of members of this forum too...who know!
I don't understand at all the information of other threads...
Material needed:
-3.3V Zener diode
-1K Potenciometer
MAP sensor wires:
Pin1: signal ground
Pin2: temperature output voltage
Pin3: 5V supply and reference voltage
Pin4: Pressure output voltage
in wich MAP sensor pin i must to install Zener diode?
Potenciometer must be connected to ground.... to MAP sensor ground(Pin1) or chassis ground?
Wich is the correct Ohm resistance? 100Ohm?
I suppose that boost is adjusted with potenciometer... A bigger value that 100Ohm is more or less boost? Thanks in advance..
Rub87remap ARLpistons PD100rods Sputters ARLbolts Rosten'sMainStuds VitonSeals PortedHead Rosten'sValveSpring ASVpump 11mmHead DE143 11mmSprings GT18v Race520 BigFMIC fuelCooler LiftPump CRfuelFilter PD130Manifold Dbilas260cam BlackLifters OilCooler 312mm+porscheCalipers Sigma5SSK BilsteinEibach MK4RearBearings/Calipers EibachProKitSwayBars
Satiro is offline   Reply With Quote
Old March 18th, 2008, 03:02   #2
Satiro
Satiro's Avatar
Wich Pin is the VE wire?
Old March 18th, 2008, 06:09   #3
93FryGuy
93FryGuy's Avatar
What's ve?
From what I read here the number 4 pin is what you want.
Then connect the zener diode with the negetive end to the #4 pin, then to a potentionmeter you can control, then to chassis ground. I think I have finally made sense of it for THAT car.
But that was on a different TDI engine than either of ours, so I am not sure how it works on our. I dont think we even have a MAP sensor, but then again, you are in Spain, I am in US, so dunno the differences are, its so confusing sometimes.....
On the page you got that diagram from, he said is is possible to do it with the controls I have, and I am trying to find out how this is possible, need to look around somemore, OR anyone here be kind enough to explain how this is done to a 1998 1Z TDI?
1998 Volkswagen Jetta TDI(duh) 1Z engine
1993 Chevy K1500 6.2L running on diesel and V100 (100% vegetable oil)
1996 Polaris Sportsman 500 (the only gasser I will ever own)
93FryGuy is offline   Reply With Quote
Old March 18th, 2008, 08:54   #4
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
Should this be the same for a PD?
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old March 18th, 2008, 09:06   #5
Satiro
Satiro's Avatar
Wich is the approx value resistance for 1.3bar from stock map?
Old March 18th, 2008, 11:09   #6
hakansson
TDI(s): Octavia98:a
I have no zenerdiod I have only 20Kohm and that give me 1,35 bar.
hakansson is offline   Reply With Quote
Old March 18th, 2008, 11:48   #7
mctdi
TDI(s): 2010 Jetta
Question
This might work on PD. But having played with bad wires to the turbo vane position sensor, only on the PDs, and seeing the requested and actual MAP & MAF values both before and after repairs; I think not likely.
As the turbo vane position sensor seems to have more input [ control ] on the running boost pressure then the MAP sensor does.
Without the turbo vane position sensor connected [ working ] actual MAP was always running about 10 PSI at cruse. This while requested MAP might be say 6 PSI. If pressure spiked to something above 13 PSI, then it was reduced, so there was still some pressure control.
With the turbo vane position sensor connected the actual MAP was always close to the requested MAP. And the same for the MAF.
Maybe Jeff-RC, or some other chipper, could add some solid insight on this matter. As I would like to know if the turbo vane position sensor does have more input to actual boost pressure than the MAP sensor?
Ben / mctdi
10/24/2015 => 300,262 miles
5/29/2010 Jetta 12 miles [new],
R.I.P. 2004 Golf 362,993 miles,
mctdi is offline   Reply With Quote
Old March 18th, 2008, 12:04   #8
andypandy
andypandy's Avatar
Ill think this will be great together with bigger nozzles, with this you move the whole map uppwards... as you do with nozzles.
But ill think this will work quite good for all.
Maybe im overworked the mod a bit.
Misspelling will occur... hey try to write something in swedish and you will see! :-)
Golf TDI HL 110 AHF -00 140hp++, VNT2052, FMIC, 2.5" DP. PD150 intake etc.
Chrysler Grand Voyager LE
andypandy is offline   Reply With Quote
Old March 19th, 2008, 16:54   #9
Satiro
Satiro's Avatar
WOW! i installed it this morning... i installed one 3.3V zener diode and 100Ohm resistor... my boost is 1.7-2.0 bar!!! INNACEPTABLE!
I have MAF mod too... can the MAF mod to increase boost? for to obtain less boost is needed more or less that 100Ohm?
Old March 19th, 2008, 18:21   #10
Rub87
Dude, really.. this mod sucks ass..
When you want to do it right, use diagram that looks like the on I posted here somewhere, use an opamp..
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old March 20th, 2008, 02:41   #11
Satiro
Satiro's Avatar
Please guy, can you explain a bit this diagram? What's a 1/2 LM158? Wich's the Zener value and how connect it? where goes the arrow in the low-left part of picture?
Old March 20th, 2008, 11:12   #12
Satiro
Satiro's Avatar
have you installed a 20K Ohm resistor only? say that gives you 1,35bar...wich is your stock boost?
Old March 20th, 2008, 19:53   #13
mctdi
TDI(s): 2010 Jetta
A "LM158" is an IC chip that has two summing amplifiers in it. This circuit only uses one amplifier, so one half [1/2 ].
The arrow is the center tap, or wiper of a 10k ohm potentiometer, variable resister.
As to the Zener Diode, the circuit looks to be missing that information.
I hope his is of some help.
Ben / mctdi
Old March 22nd, 2008, 05:51   #14
Rub87
You use a zener as an resistor to create a stable reference voltage..
12v--> zener --> resistor
Now you have a stable voltage, as much as the zener voltage between de zener and the resistor.. Remebet this diagram I gave for using the 3 bar map man reducing the boost..
If look at the internet and use common sense you will soon find a diagram that you can use to raise boost with a 2.5bar map sensor..
The easiest way is just to use a Ge diode in series with the signal wire..
If you use the "differential amplefier"basic opamp circuit you will be able to regulate boost easy and accurate..
Old March 22nd, 2008, 14:16   #15
Satiro
Satiro's Avatar
I installed a zener 3.3v diode and 1k pot... first adjust of pot gave me 1.6-1.7bar... i turned pot a bit and give me 1.3-1.4 bar sustained...
Now... when i turn on evry mod have some boost spikes, i have one boost-valve but i can't to adjust it correctly...
I use an air compressor, adjust pressure to 1.5bar in compressor gauge,connect boostvalve and adjust it for to be closed at 1.4 and start to open at 1.5... install boostvalve in engine again and drive for test... 0,6bar sustained!
wich is the method for to adjust a boostvalve?
Page generated in 0.15954 seconds with 9 queries
[Output: 133.24 Kb. compressed to 110.99 Kb. by saving 22.25 Kb. (16.70%)]
