zagato27
Recently purchased the Torque App and am in the process of setting it up. I'm sure that their are others that have done this. How bout posting some tips and screen shots. Thanks in advance
Well it's been a week, are you having fun with it yet?Recently purchased the Torque App and am in the process of setting it up. I'm sure that their are others that have done this. How bout posting some tips and screen shots. Thanks in advance
Ah, WOW! Lots of stuff there. I'm a bit "visually challenged", I wear glasses and I sort of need a screen that isn't quite that busy. Could you amplify on the "VW OBD II" setting and the "generic" settings. I'm a bit confused. DPF and EGT values, who knew. I'm currently using a "skin" from a Passat I believe, blue numbers and red sweeps. It' nice. Yeah, I'm still learning. I recently got a Pro Clip and it's great. I'm finding that I'm using my Galaxy S3 for a lot.....BT streaming of audio books on the way to work and also WAZE. Getting hard to squeez in TORQUE.Well it's been a week, are you having fun with it yet?
I've had mine about a year now, nearly 70k miles of experience with it....
Lots of stuff to play with, don't take the numbers too scientifically....but it certainly has value. While I like to cram as much on one screen as possible, you don't have to be able to read it all. I'll have tiny dials for egt that only flash when high, to get my attention. I've also messed with the art of gauge layering.
Get the vehicle profile as good as you can, it helps, and try out both the VW OBDII setting and generic setting, to see which you prefer. Mine is set to non-generic.
Here's some samples, cheers.
What brand Elm327 do you have? My Ebay special won't work on my tdi, but works on my Toyota.
Sent from my SGH-I337M using Tapatalk
Might be referring to my VW set I posted. http://forums.tdiclub.com/showpost.php?p=4268210&postcount=8Ah, WOW! Lots of stuff there. I'm a bit "visually challenged", I wear glasses and I sort of need a screen that isn't quite that busy. Could you amplify on the "VW OBD II" setting and the "generic" settings. I'm a bit confused. DPF and EGT values, who knew. I'm currently using a "skin" from a Passat I believe, blue numbers and red sweeps. It' nice. Yeah, I'm still learning. I recently got a Pro Clip and it's great. I'm finding that I'm using my Galaxy S3 for a lot.....BT streaming of audio books on the way to work and also WAZE. Getting hard to squeez in TORQUE.
That was the exact unit I had before I switched to my OBDLink LX. Descent enough adapter, but my OBDlink is a whole lot faster and I can leave it plugged in without worrying about battery drain.Assuming you are talking about a BT OBD II scan tool. Bought this one off Amazon, it was recommended by another user. Works on my '12 JSW TDi and the price was reasonable.
http://www.amazon.com/gp/product/B005NLQAHS/ref=cm_cr_ryp_prd_ttl_sol_25
You should note that the more information you have on screen, the slower the information gets read. The OBDII reader can only pull so much information at a time. And those cheaper Amazon units only read ~25PIDs/sec.Lots of stuff to play with, don't take the numbers too scientifically....but it certainly has value. While I like to cram as much on one screen as possible, you don't have to be able to read it all. I'll have tiny dials for egt that only flash when high, to get my attention. I've also messed with the art of gauge layering.
For the life of me, I can't find Torque in my foldersThere are VW specific PIDs. Let me see if I can find the source for them. I downloaded them from somewhere and plugged them into the Torque app. They have been much more accurate than the generic PIDs listed by default in Torque Pro.
Here we go:
hotpocketdeath said:
"Here is a csv of my current custom Guages in torque
https://www.dropbox.com/s/kapw0cjp2prxuts/VW.csv
Just download it and stick it in the folder: "...\.torque\extendedpids\"
Load up Torque, go to settings > Manage Extra PIDs/Sensors > menu > Add Predefined set > choose "VW"
The boost guage is defaulted to reporting absolute manifold pressure (boost + barometric). If you want, you can edit the equation to auto subtract barometric pressure. the equation would look something like this:
(((D*256)+E)/32)-([ff1270]*.1)
The variable [ff1270] is the barometric pressure reported by my android phone. I used my phone because it's one less piece of information that the car needs to report since those Bluetooth dongles can only read so much info at a time. Your phone might be different. Use torquescan to find out your variable. The ".1" is simply a conversion from mBars to kPa so that it can work in the equation."
And yes, it's at the link in post #8. Wish I looked at that first before digging elsewhere online
