Hi, i have an audi A4 2000 mod 1.9 tdi tiptronic, and in the last week the car suddenly starts to shake and loss off power, and when i switched on off the ignition and then it run normaly almost every time, for a little while somtimes for 10 sek and somtimes a few minutts, when i take a fault code reader and the codes i Get is: P1264 PD unit injector , cyl 4 (n243) regulation range exceeded and P1267 the same but cyl 3 (n242)
And the last fault code is P0304 cyl 4 misfire detected, the car doesn't go into limp mode, and when i give full trottle the engine always work perfekt over 3000rpm but in normal city driving with low speed then this shaking and poor performance kicks in.
Can sombody please tell me what this is that have happend and what parts do i check or replace, or is it sombody so have had the same problem ? I need some hjelp with my car.
Best regards John.
Best regards John.
