manual transmission swap parts needed?
leonwold
canada
2003 jetta
Hey I'm parting out a jetta and someone with an automatic wants to buy all the parts necessary to do a manual conversion on their golf. Could anyone that has done this give me a list of all the parts he would need?
Combine17
Ontario - Hamilton
2001 Golf GTD
1. Shifter Linkage
2. Left 5spd Axle
3. Right 5spd Axle
4. Dogbone (engine mount)
5. Clutch Slave Cylinder
6. Clutch Slave/Clutch Pedal Metal Line
7. Foam for Shifter
8. Clutch Pedal with Hose
9. TDI Starter (low km)
10. Shifter Weight with catch spring
11. Shifter Arm with catch spring and lock clip
12. Clutch Switch with Connector
13. Cruise Switch with Connector and bracket
14. Pedal Switch with Connector
15. 2 Relay 53 (one extra)
16. Shifter to Center Console Bracket
17. Clutch to Brake Bracket
18. Flywheel Cover Plug
19. Shifter Tower Cap
20. Shifter Tower Nut
21. Reverse Switch with Connector
22. Starter Cap
23. Clutch Line Clips
24. Clutch Pedal Hose Clamp
25. 2 Starter Bolts
26. 4 Shifter Linkage Bolts/Nuts (hold shifter in place)
27. 2 Center Console Bracket Nuts
28. 3 Shifter Linkage Bolts (in engine bay)
29. 2 Slave Cylinder Bolts
30. 2 Clutch to Brake Bracket Nuts
31. 3 Clutch Pedal Nuts
32. 2 Shifter Tower Bolts
33. 4 Dogbone Bolts
34. Power Steering Line
35. Transmission
that should get you started
jimbote
Certified Volkswagen Nut
Tacoma 4x4 converted to TDI
add to the list above ... engine tins (large and small plate with bolt) ... and flywheel/clutch ;)... also why do you specify "shift tower bolts" ... no need to remove those on swaps
Combine17
Ontario - Hamilton
2001 Golf GTD
the only reason is that ive seen trannys being sold without flanges, shift towers etc...literally ONLY the tranny. wont hurt to have a check list :)
leonwold
canada
2003 jetta
I think it would make more sense to sell the whole car haha. Or the hulk I have left over at least. That would be easier
