stanz
2009 Jetta TDI with DSG. Time for tranny service. Can I drain fluid measure quantity change filter and top fill? Not to concern myself with fluid temperatures and VW refill tool. Is this acceptable practice?
Yes, I did mine that way at 40K and preparing for the 80K shortly. You don't need to measure as this is a fairly complete drain. There is a thread here with photos describing how to use the plastic insert in the drain hole to set the fluid level. Temperature will be important as the DSG is pretty sensitive to fluid levels. Check this thread for a detailed DIY: http://forums.tdiclub.com/showthread.php?t=1693562009 Jetta TDI with DSG. Time for tranny service. Can I drain fluid measure quantity change filter and top fill? Not to concern myself with fluid temperatures and VW refill tool. Is this acceptable practice?
This is acceptable and accurate. You do not need a VCDS to do this procedure.I've read many people top fill using 4.6 liters of fluid through the filter housing. My dealer says I need 5.2 liters. If when done at a dealer they put in 6 and drain some back out using their very expensive cable to read temp, why would they tell me I need 5.2 liters instead of so many here telling my drain it, pour in 4.6 through the top fill method, install new filter and be done?
I doubt the dealer is only overfilling by .6 liter, I would strongly suspect they put in the full 6 bottles and then drain some back out. This entire procedure is ridiculous, but I'm hoping for a consensus as to how much to put in via the top fill method to keep this simple.
Exactly. Fill either way. Just make sure you DO IT!The entire procedure is pretty common on many automatics nowadays, and if you have the correct tools it is pretty easy and foolproof.
There are even nice aftermarket ATF fill kits that have the 02E type adapter as well as a bunch of other popular and useful ones. I don't see why people get so bunched up over this.
Amsoil has the Audi ATF Audi G-052-025-A2 or G-052-162-A1 I really like our product but if it is unacceptable I will not risk it. As fare as I know it may already be rated G 052 182 A2 just has not been released yet.Thanks BillAs to using smme other specification Audi oil, why not use the specified oil? Is it worth the savings if you do screw up the transmission?
just wondering.
JDB.
