makoola
I have the crappy annoying thing happening with my 2002 Jetta wagon where the driver side front and rear floor boards are getting soaked (1-2 cups of water coming in on a good rain). I can see water coming in on the rear driver side floor from the air duct below the driver seat. And on a good rain, i can see water dripping in from the door (at the location of the little rubber gutter on the underside of the door, near the front speaker) at a good pace when it's really raining. I've read a bunch of threads but still have a few questions on how to solve this correctly:
1. Water in from pollen filter housing. I found this thread that summarized the same thing for a 04 Passat:
***** ****Begin Quote**********
I had some minor leaking around the base of the cabin filter tray. In case anyone missed it, I'll repeat...you must remove the entire cabin air filter housing to properly repair this (it wasn't hard if you ask me). In order to do it, you must remove the windsheild wipers and the cowl (the plastic trim at the base of the windsheild). There are nuts under caps that hold the wiper arms on splined shafts driven by the wiper motor. Use tape to mark the position of the wipers on the windsheild, pry the caps off with a small screwdriver, and unbolt the wiper arms. It may take a good tug to free the wiper arm from the splined shaft. With the wiper arms removed, remove two clips and one philips-head screw and the cowl can be lifted straight up in relation to the ground. It seals with a metal lip under it sort of like a zip-lock baggie would only with a little more strength. My advice is start at one edge and/or the other and work toward the center. Remove the cabin filter cover and the cabin filter. There are three small nuts that hold the bottom tray of the cabin filter housing (VW calls it a frame). The two of these closest to the fender/hood hinge may be difficult to get to unless you have some tight access 1/4" drive tools. Once unfastened, lift out the frame and you will see a bunch of debris and two seals underneath. The innermost seal is not at issue...its an airflow seal for the proper function of the air handling system. The outermost seal is some sort of closed cell foam and mine was actually torn from the factory and was also installed crooked. I chose to replace it with some strip Dum Dum (weatherstripping from a body shop). Any proper weatherstip of the appropriate size that can be made into a continuous loop should do the trick. Getting the right size and not having a gap are the keys. This "Dum Dum" that I used was similar to modeling clay, so it won't harden and it can be formed and connected, yet it doesn't sag or shrink.
Best of luck...and keep the cowl clean. Your vigilence will be rewarded by a lack of costly leaks.
++++++++++++++++++++++End of Quote+++++++++++++
Is the idea here to follow the above description and reseal the area where the bottom of the filter housing attaches to duct that leads to below the driver seat? Or to seal the housing against the frame of the car? I couldn't find any good pictures of this.
2. Leak in Door coming from where? Is there a shield on the door that prevents water (that is coming through seal of glass and window seal) from coming into the door? Can I just remove the rubber thing? Seems it's trapping water that is running down the perimeter of the door from the roof gutter. What's the likely culprit and way to fix this one?
Any thoughts are appreciated.
Thanks!
makoola
2.
Thanks!
makoola
2.
