dislexicmofo
I looked for a while and didn't find a good how to for this on the tdiclub site. I ended up having to google it; it's scary in other forums so I thought I would make it so others never have to leave!
First, the parts... you only need two tools. the first is the dial indicator itself, the second is a bridge to hold it while you measure.
Depending on why you are checking the protrusion accuracy is not as important as consistency. If all you are doing is checking for a bent rod, you just need to know if on piston is "off" from the others. If you are doing anything else you probably already know what you need.
I got this digital indicator form harbor freight. It reads in inches and mm and you cane tare it to zero which is handy.
https://www.google.com/webhp?source...sb&fp=c4aec0292ce16d20&biw=1280&bih=702&ion=1
If you buy snap on products and just like to spend lots of money on tools (kidding) you can get nicer ones here: http://www.mcmaster.com/#dial-indicators/=ghngtd
The next thing you need is a bridge, I got mine from summit racing since they are close and ship same day. It's the program three hole stand in the search results. Jeggs also has some if you want to get it form them. They are all the same really, my only recommendation is getting one that has multiple holes as they come in handy (get your mind out of the gutter). If you want to step it up some come with magnetic bases that will help you get a more accurate reading.
https://www.google.com/webhp?source...sb&fp=c4aec0292ce16d20&ion=1&biw=1280&bih=702
Now you are ready to get started! first you need a clean block (deck) surface. if you search the forums I have a thread on how to clean it (it's here http://forums.tdiclub.com/showthread.php?t=344585). It should look like this:
To measure the protrusion first bring two of the cylinders even with the block deck. Place the dial indicator into the bridge and set it to measure the height of the block surface. tare the indicator to zero, and shift it over to measure the piston in one of the four corners. Now get your buddy to slowly turn the crank until the dial indicator goes up to a max level and then start to come back down. Now tell your buddy to turn it the other way. then the other way. then the other way. etc. until you have a maximum height reading for that corner. now shift to another corner on the same piston, rinse and repeat. After you have four readings for each cylinder take the average reading for each.
tare to zero on the block deck:
Find the highest point in the travel:
If applicable make sure your "buddy" is your dad. You both will thank me later. He will also have better handwriting. Note: You are never to old to ask your dad to help you work on your car.
Continue to measure until satisfied. You will never get the same reading twice, thats just science. You could measure two hundred times to get a better data set but it will never be perfect (engineers will understand).
After you are done you should have a bunch of tiny numbers (remember that 0.94756234 millimeters!). If they are all roughly the same you have no bent rods! if you one jumps out at you as "off" now is the time to start drinking, heavily, because its going to be a pain in the ass to fix it and you have likely gotten yourself into something over your head !
