schwartzbass
I have read about all of the problems with IP, but I can't find my problem...
I have a 2001 jetta TDI. After letting it sit for about 1 week I found it would not start. The clear fuel line to the IP was empty so I guess I have a leak somewhere. I used an oil extractor as a vacuum source and verified that I can pull fuel through the fuel filter. When I put the vacuum on the return line from the IP I can't get any fuel to come out of the pump. The vacuum holds pretty well so it is not a gross leak that is preventing the fuel flow. I used the starter to rotate the pump a few times with the vacuum on the return line and still no fuel out of the pump.
Any ideas of what could be wrong?
