ECU Info
shortysclimbin said:
Jake,
Thanks for the info. I figured that is what you ended up doing. Can you go into more details on what you are sending for info between the ecus?
I would be very grateful to see more pictures and maybe to see this thing in person. I honestly feel 150mpg should be cake with hyper-mpg techniques. It also sounds like there may be a few options to optimize the ecus to get the system to provide the best service.
I am not a 100 percent sure on the 1.2l motor but what a lot of us have found that around 2k-2.2k RPM is the proper rpm for setting high mileage records. I have a feeling the honda ecu is not designed to switch over for the right rpm level for that diesel motor. Being able to maybe increase the rpm (IIRC the insight swaps over at 35mph) then you might be able to increase the efficiency of the system. You might also be interested in looking into 0w-40 elf oil and a custom made oil scraper for the car. This could net some better efficiencies in the engine itself. Other modifications would get into the expensive side and may be left better of on trying to reduce rotational weight on the body itself and reducing drag in the drivetrain.
It's easiest to think of the VW ECU as the provider of signals and the Honda ECU as the receiver of signals from the "Translator". The Translator serves as the electronic bridge between the two ECUs. Substantially, it takes VW formatted signals and transforms them into Honda formatted signals. The VW ECU provides: 1. Throttle position, 2. Manifold pressure, 3. Engine coolant temp, 4. Intake air temp, 5. Crank position. Without going in to how the Translator operates, the Honda ECU receives: 1. Throttle position, 2. Manifold pressure, 3. Engine coolant temp, 4. Intake air temp, 5. Crank position, 6. Cam A position, 7. Cam B position.
I can't figure out how to insert pictures within a post. Is there a good way to do it?
I would be happy to show the car to anyone who's interested in seeing it. Additionally, those that I consider proficient drivers will be invited to drive to provide thoughts and feedback about the design.
I've been transferred to the West Coast (Anacortes, WA area) so the car will spend most of its days there. No later than this Sunday (27JUL) I'll be starting a cross country journey. Plug Patuxent River, MD and Anacortes, WA into MapQuest and that's the route I'll be taking. The car will also be at
The World of Speed this year to lay down a few max speed runs on the salt. I'll try to make other events with the car as they arise. Most will likely be on the West Coast.
My plan is to develop a max range chart by data logging fuel consumption rate and vehicle speed. I bet it will verify 2-2.2k RPM. Since data logging is so easy with OBD II systems, confirmation won't be much of a hassle.
By the Honda ECU not switching over at the right RPM level for the diesel engine I think you mean the electric assist won't be optimized for diesel torque characteristics. We are planning to adjust the way the electric assist operates by manipulating throttle position and manifold pressure through programming of the translator first. From there we could go to a more complex system and gain full control of the electric assist features of the vehicle:
MIMA .
I'll keep the 0W40 and oil scraper in mind. Because the oil pan was originally designed for an installation angle displaced from vertical, we're going to adjust it for a 0 degree from vertical installation angle for additional ground clearance. That may be the time to implement a scraper.
Best wishes,
Jake
