ndamico
Vendor , w/Business number
- Joined
- Mar 20, 2008
- Location
- Sacramento, CA
- TDI
- 2003 Golf 2Dr TDI, 2003 Jetta TDI, 2003 Jetta Wagon TDI, 2002 Duramax, 2003 Duramax
the joys of buying a used car
I've had a accessory belt squeak for a short while and figured i'd try to fix it today. what i found was the alternator was loose... and i mean the entire alternator. the top and bottom bolts were about 1/2" out.. so i grab the bottom bolt to see if it will turn with my fingers and it falls right off..sheared about 1" from the bolt head.. top bolt comes out no problem.
so i try a couple different extractors and even sawzall the ear off the alternator so i can get closer to the remainder of the bolt... i put the grip of death on that thing and finally broke one of the extractors but the bolt didn't even budge...
i've looked all over and can't see a way of removing the alternator..if i pound the bolt in, it will hit the webbing on the bracket that holds the alt, IP, etc. so i can't move it that way.
Am i missing something or do i now have to remove the IP, PS pump, and everything else attached to that huge bracket then remove the bracket itself? if it were the top bolt i could have pounded it out as there isn't an interference issue on that one but of course my luck its the bottom bolt.
thanks for any advice..
