mychevyisdead
I took my 2002 Golf in yesterday to have a diesel emissions test - the whole procedure is for the purpose of getting Colorado tags. According to the tester, "it failed pretty bad," (I do not have the results handy right now but will post them under this thread) he did note that the exhaust was coming out "rich."
After paying $58.00 to find out that I cannot drive my car legally, I talked to a mechanic down the way about the problem - to get some ideas as to what would cause the emissions failure, and how to fix it. He suggested purchasing a new air filter, one that was quite expensive (maybe a K and N?), obviously, change the oil, run out the remaining fuel, run it on a couple of gallons of 'red fuel,' refill it with a higher grade diesel, and then take it back in. If this did not work, he would then suggest testing and changing the fuel injectors, since it was evident that there was diesel in the oil.
I would like to know what you think. Keep in mind that I live close to downtown Denver, and work in downtown Denver, so I do not drive. This car had been sitting in my driveway for five or six months before I took it in for the test. I do understand that this probably had something to do with it. But if the test failed "pretty bad," is it more proabable that there is something wrong with the car's internal functionings, beyond old fuel, old oil, etc.? Please advise.
P.S. as you probably know, red fuel can only be purchased by those with a license. What is an alternative to this? The mechanic was not a proponent of the "Lucas" type of products for cleaning fuel injectors.
