Coincoin said:
Hello,
Sorry,
My car doesn't have stock alarm, i wired the siren, hood sensor,changed the comfort module(my car did not have remote central locking) and want to activate the alarm.
The siren is ok, i have bip when i close or open the car.
My car :
Golf iv TDI115
2001
Previous module : 1J0 959 799 Q
The new module : 1J0 959 799 AH
Ok, so you have electronic siren? or just the 2 wires horn?
Anyway, there are several values to change:
To activate the alarm in your CCM:
- read out value at address 4281. It will normally have value of '1'
- if it is 1, then the new value will be 255 (or $FF in hex format); if it is any other value, just make 0 the Least Significant Bit... (a shortcut is to substract 1, but if the last bit is not one, then it will create a problem)... Hmmm, using the calc of your computer, convert the value that you have to binary, and add '0'es on the left until you have 8 digits... then take the last one and, if it is '1', then make it '0'...
- Write the resulting value (255 or the calculation result) at addresses: 4281, 4287 and 4293.
To activate DWA siren, in the event of having it:
- Read the value at address 4285
- If the value is 255, then the new value will be 112
- Otherwise, convert it to binary, complete until you have 8 digits, and change to '1' the 3rd bit, starting on the left... the 5th bit starting on the right... Convert to decimal again and...
- Write the resulting value (112 or the calculated) at addresses 4285, 4291 and 4297
Please feedback... if you have any issue, just return to the original values and let me know. Good luck.
