ZDNet: Volkswagen lied. But Elon Musk is dead wrong about diesel cars
nwdiver
Texas
2003 Jetta TDI (sold); 2012 Tesla Model S
I admire your enthusiasm!!
Now,. Please tell me why you are not taking your own advice?
To be perfectly blunt, I am trying to figure out why you are not putting your money where your mouth is if it is such a no brainer. When are you buying a used Leaf? Please post pictures of your own solar set up.
I bought a Tesla ~3 years ago. If that had been out of my price range I absolutely would have either a Volt or a LEAF.
I installed ~10kW of solar at the same time my Tesla was delivered. The PV has produced ~48MWh while the Tesla has consumed ~25MWh driving 76k miles over the last 3 years.
Solar pic: https://scontent-lax3-1.xx.fbcdn.net/hphotos-ash2/t31.0-8/1272081_607856632599170_1246095876_o.jpg
john.jackson9213
Miramar, Ca. (Think Top Gun)
1996 B4V
Great! Really do love to see these installations and real world experience. I admire your willingness to follow thru with your own $$ and the installation! Not too many willing to do that.
A fellow I used to work with purchased a new Leaf and installed a large (but used) solar system. Did the install himself and is rather happy with the results also. His wife uses the Leaf as an around town car.
My own problem is that I can not really justify a solar system when my (natural) gas and electric bill averages less than $140/month. Half the year, it is under $100/month. In winter the spike in energy cost is for natural gas, not electricity.
nwdiver
Texas
My install was also DIY; It's crazy how much money you can save. I also upgraded from 60 => 200 amp service when I did the install so the cost came in around $18k for everything but I'm saving $200/mo. You can build a 10kW system today for ~$10k w/o the tax credit.
My home was also gas when I got it. I replaced the hot water heater with a GE Geospring heat pump; HVAC with LG mini-splits and the stove. The gas company was charging me $15/mo just to have service so I canceled that ~6 months after I moved in. 100% electric now and I generate ~2x what I need annually.
It's nice looking forward to your electric bill ;) Oooh another check!
Lug_Nut
Sterling, MA. USA
2015 GSW 6M in S trim the other oil burners: 1967 two stroke Sonett 1988 Bolens DGT1700
1 kWh of electricity drives an EV ~3 miles (15g/mi)
1 kWh of B100 drives a TDI ~1.5 miles (24g/mi)
2.9 miles, near enough to 3 miles/kWh, that I can buy that. Where I will disagree is the 15g/mi emission.
Tesla's touted cross-country run on their Supercharger network used 1197.8 kWh to cover 3,464.5 miles.
Using data from the Tesla blog as to the amount of power consumed at each of the chargers they used, calculating the grid average for CO2(e) for that region as identified by the eGRID sub-region, and summing it all up shows that the trip emitted CO2(e) of 753.9 KILOgrams. Divide that into the 3464 miles and the rate per mile is 217.6 grams per mile.
And my TDI Cabro conversion was also slightly lower at 1.4 miles per kWh.
My trip in the opposite direction to the TDIFest in Portland on public access, commercial retail pump biodiesel (B99 and B100), covered 3,934 miles on 80.166 gallons (at 119,500 BTU, or 35 kWh each gallon, or 1.4 miles per kWh). Using the energy intensity and CO2(e) factors for the various feedstock (VO or WVO or lard, B99 or B100), the CO2(e) for my trip was 600 Kg or 152.5 grams per mile.
There's no debate that the Tesla is more efficient at converting energy into distance at a rate equivalent to about a 99 mpg on gasoline, while my TDI conversion was about 48 mpg per gallon of gasoline energy equivalent, but the Tesla's emissions were equal a 52 mpg gasoline vehicle and mine were equal to a 75 mpg gasoline vehicle.
Whether it's nuclear, wind or solar... any clean, sustainable and scalable energy source needs electricity as an intermediate step. That being what it is... doesn't it make logical sense to use that electricity as much as possible?
Not when photosynthesis and the resulting biomass are far more energy efficient in converting solar energy into a storable form.
nwdiver
Texas
try 3 kWh/mile. Tesla's touted cross-country run on their Supercharger network used 1197.8 kWh to cover 3,464.5 miles.
Hmmmm.... I'll let you find your math error...
Not even close;
Algae to Biofuels (the most space efficient biofuel) produces 15k gallons (555MWh) per acre per year. That same acre would produce 657MWh of electricity annually (this includes spacing between rows). A tracking array in AZ, NM or TX could easily produce 1000MWh/yr.
657MWh in an EV is 1.9M miles
15k gals @ 50mpg is 750k miles
And that's a Model S vs a Jetta... no where NEAR the same class of vehicle a Mercedes S class is closer to 35 mpg.
So solar PV is 2-3x more effective than biofuels with FAR FAR less maintenance.
Nearer 3.5 kWh/mile, but OK.
You're getting colder... ok... I'll give you a hint... if you needed to consume 3.5kWh for every mile... and you travelled 3464.5 miles... you would need 3464.5miles x 3.5kWh = .......
You're doing your math backwards... it's ~2.9 miles per kWh (0.345kWh/mile)... apologies... I was 5% off.
nwdiver
Texas
LOL... man... no wonder some people hate EVs so much... you think they use ~10x more energy than they do! I'd think they were dumb too if they really used 3.5 kWh/mile ;)
Lug_Nut
Sterling, MA. USA
You beat me to my correction. I hit submit, then in an instant realized what i'd done, and have been re-doing it before seeing your posts.
Please review the corrected version now up in post 34.
I don't 'hate' EV's. It's about me deciding for myself that I can do better, if not necessarily 'greener' then certainly less 'brown', than to go electric for my personal transportation.
nwdiver
Texas
I must have missed it... the correct answer is ~2.9 miles per kWh or 0.345kWh/mile definitely no where near 3.5 kWh/mile.
Your choices were obviously being informed by incorrect information. Per unit area Solar PV is also 2-3 times more efficient than biofuels before maintenance requirements are taken into account.
15g/mile is based on solar PV which is expanding ~10x faster than EV consumption.
Lug_Nut
Sterling, MA. USA
That'll teach me to use a 'solar' calculator with 15watts of lighting.....
Yes, 2.893 kWh/mi. Which is equal energy consumption to about 99 mpg on gasoline.
I'll re-re-edit the post 34.
I'm personally more concerned with the environmental aspect than an efficiency.
Using current CO2(e) calculations, PV, over it's expected life, will have 'produced' about 36 grams of climate change equivalent per kWh produced.
Biodiesel from post-consumer waste, fuel which I can conveniently purchase, will have 'produced' about 24 grams per kWh of energy produced.
nwdiver
Texas
Cool... edit it so it reads 2.893 miles/kWh (the correct units ;) ).... not kWh/mile... BIG difference.
You're missing the point.. you need ~3x as much post-consumer waste to do the same amount of useful work... I can travel 2.89 miles on 1 kWh. An ICE can only go ~1.5. 24g/mile is not less than 15g/mile.
Also... 99mpg = 0.34 kWh/mile; 33.7kWh/gal / 99mpg= 0.34 kWh/mile; You're doing the math backwards.
romad
Prescott, AZ
2005 Jetta GLS Wagon "Cranberry"
Could someone scale the photo in post #31 down to a proper size? It takes up about 120% of my screen width!
nwdiver
Texas
Apologies... I couldn't figure out how to post photos from my computer...
Lug_Nut
Sterling, MA. USA
2.893 mi/kWh.
I believe that my point is being missed or intentionally ignored, that energy from waste, from products that are already 'used-up' and would otherwise require additional energy for disposal, is a positive energy return in additional to the energy contained in the re-used product.
Make the PV panels from CRT monitor screens, powered by landfill methane, wired with copper collected from the acid rain run-off from the Statue of Liberty and I applaud the work.
Leave the Tesla at home to charge from the solar panels when they are working, rather than from the dirtier power made when the sun don't shine, and that will be nearly as low emission as biodiesel.
Let the grid utility purchase your excess day power at the same wholesale rate they pay their other power suppliers, rather than the retail rate you force them to pay, and re-calculate the payback rate.
The issue is far more complex than you and I can really take the time to fathom, and it appears that you and I are the only ones that have any interest in perpetuating this thread, and for what purpose?
I think my choice is right. You believe yours is. I'm still convinced that my change to an electric car would be a step back from a greener alternative that I presently have. I also am pretty sure, based on your postings, that you are fully convinced that you can't do any better than what you have now.
So it's a stand-off, and we should stop.
OK, It's a stand off and I'll stop. You may continue on as you wish.
nwdiver
Texas
So let's parse the facts and opinions a bit... I did drive a B100 fueled Jetta for a few years. Several realities became clear and motivated me to pursue other alternatives.
- For obvious reasons the amount of fossil fuel you can displace with waste oil is a rounding error in the grand scheme of things.
- Very little waste oil is wasted. I could no longer get waste reliably since it was collected by a commercial collector. Oil I didn't get wasn't throw away... it displaced diesel somewhere else. The fact I no longer consume that oil hasn't increased the flow to a land fill... it displaces more diesel.
- Liquid fuels should generally be conserved for areas where there currently exists no viable alternative such as aviation.
We always have to be wary that we're not twisting reality to fit our choices. Adjusting our choices to fit reality increases the odds of success. Perhaps I'm wrong... if there is an error then it isn't a matter of opinion but of fact. My choice is based on the following facts... if there is an error please point it out.
- EVs get ~3mi/kWh vs 1.4mi/kWh (50mpg) for ICE
- The US currently uses 270B gallons of petroleum products per year.
- For simplicity converting that to electric reduces that energy by 2/3 to ~90B gallons equivalent.
- 90B x 35kWh = 3150 TWh/yr
- Current US electrical consumption is ~4000TWh/yr
How much area to generate 7500TWh/yr from solar alone?
- A 10MW solar farm can generate 25GWh/yr and occupies 0.04 square miles.
- You would need 300k 10MW farms occupying 12k square miles.
- For scale there are 3500 square miles of golf courses in the US and 61k square miles of paved surface.
Even from non-recycled material Solar PV easily beats any fossil fuel from the perspective of ecological impact and unlike liquid fuels it can be easily scaled to meet all our energy needs.
Cost and not wanting to realistically add ~10% to your travel time for the occasional road trip remain valid reasons EVs may not fit... sustainability isn't one of them.
To reiterate a few points so as not to give the impression I'm ignoring your point... recycling is critical and obviously a PV module built from non-vrigin materials is preferred over mining new materials... BUT its not like forgoing the cost of building new PV modules is in any way better than continuing to burn the fossil fuels it would have displaced.
The imbedded emissions in an electric vehicle are also large but the increase in efficiency vs ICE is high enough that it will save the amount of energy required to produce it after ~80k miles.
The reality is that the numbers simply don't support the notion that we can even make a dent in our fossil fuel addiction by relying heavily on waste products and recycled materials. Obviously cost is still a barrier so some of these alternatives may not be available to some people for a few more years.
Random_Vibration
Florida
2015 Golf SEL TDI (6MT, LP, Driver Assist)
I like Elon Musk; SpaceX, Solar City, and Tesla. But you have to keep in mind that old expression, "When you're a hammer, every problem looks like a nail". Of course the only way forward is his way. He's selling a product...a very expensive one that is impractical for many but a good one nonetheless.
I hope he is successful in his business ventures but his cars to date do not meet my use and budget expectations and won't anytime in the near future. I am not moved by his opinions when they contradict mine. He sells an awfully expensive product with limited range and constrained recharging opportunities. If I need to make special plans to get from A to B, it's too much of a hassle.
Opinions are many, they differ, and I don't need to know everyone else's.
nwdiver
Texas
The goal of Tesla has always been to work their way to a cheaper EV by using high end margins to fund R&D. $140k sports coupe (roadster) => $80k 5 series equivalent (MS) => $35k 3 series equivalent.
Don't conflate fact and opinions... the fact is that most road trips only take ~10% more time... it's your opinion that 10% more is 'impractical'. BEVs also use ~60% less energy to operate. ~80% less if your energy source is Solar PV.
turbovan+tdi
Abbotsford, BC.
2003 TDI 2.0L ALH, auto, silver wagon, lowered, Colt stage 2 cam, ported head,205 injectors, 1756 turbo, Malone 2.0, 3" exhaust, 18" BBS RC GLI rims. 2004 blue GSW TDI, 5 speed, lowered, GLI BBS wheels painted black, Malone stage 2, Aerotur
Right and as pointed out, EV's aren't suitable for long trips. EV's have a place, long trips aren't one of them.
Tesla with the 85 kw/h battery has a range of 465 km's IF all the ducks are in a row, so I am heading to Red Deer on Fri. Using a Tesla, I could make it to Kamloops, then I'd have to wait 75 mintues for it charge, wife is going to love that, so off we go, I can make it to Golden and another 75 min wait, off we go. I reach Banff and have to do a small charge as I can't make it to Red Deer on a full charge so another 40 min wait and off we go, and reach our destination. Wow, I paid $85K, plus tax to take an additional 3 hours, woo hoo. Go green, :cool:
So if I took my Jetta diesel, which I paid $2000 for, I would have stopped once, maybe twice, for a pee break and to fill up, so maybe a 40 min stop(s) in total. Cost of trip, $60. Go green, :D
Edit, charging times are based on the fact that no one is unplugging your car to charge theirs, :p
turbovan+tdi
Abbotsford, BC.
nwdiver
Texas
So... I'm gonna call those myths 7 & 8 ;)
Myth 7 It takes 75 minutes at a supercharger;
superchargers charge at 135kW. That's 600km/h. Most Supercharger stops are <30 minutes.... it tapers off A LOT towards 80% but you don't need more than that to make it to the next charger. 95% of the time I stop my car is ready before I am. There actually is a Supercharger network to Red Deer. A trip to Red Deer would be ~10 hours of driving and <2 hours of charging at four charging stops. Most people aren't going to drive 10 hours without a stop for lunch so you're realistically adding 1 hour of travel time. 1hr to save ~$50 in fuel...
Myth 8; Yeah... the charger gets locked into the car and cannot be removed unless the car is unlocked... so no, your car cannot be unplugged... unless you forget to lock the car.
saGhost
Wilmington, DE
2003 Jetta GLS Alaska Green ESP [sold] 2012 Chevrolet Volt
That's a way to do the trip, but not the best one. You happen to be taking one of the only routes in Canada with a full set of superchargers.
Because of the charge taper, a Tesla gets much more energy from a few minutes near the bottom of the charge than near the top.
So starting with a fairly full charge, it'd be drive to Kamloops (~60 kWh used), then charge for ~15-20 minutes while using the bathroom and getting a snack (getting ~35-40 kWh back,) then drive to Revelstoke (33 kWh used.)
Take a quick break there, too, and get another ~30 kWh to drive on to Golden (26 kWh used,) another quick stop before going on to Canmore (29 kWh used,) a slightly longer stop (meal?) before heading on to Red Deer (42 kWh used.)
By doing more shorter stops and keeping the battery low, you need a lot less time. Oh, and there's a website full of useful information about this, where I got all the details. I'm not positive if the trip I punched in will carry through on the link or not, but I'm sure you can figure out how to use it:
https://evtripplanner.com/planner/2-5/?id=imgu
Total distance 652 miles (~1040 km,) total power needed ~190 kWh, meaning you need about 115 kWh from superchargers, which is less than an hour of charging if you spread it out so that the car is always in the fat part of the Supercharger curve - and should mostly happen during your bathroom and meal breaks anyway.
I've been doing a lot of research into Teslas to see if I can give up my Volt yet, and it's getting close. :)
Walter
tadawson
Lewisville, TX
2013 Passat TDI SEL, 2015 Passat TDI SEL
Of course, all this e-nonsense also makes the fairy tale assumption that like magic, nobody else will ever be charging . . . in which case you wait for X cars in line * cycle time, quite unlike 5 minutes or so max per car at a pump. But gotta love the e-tard fairy tales though . . . like magically a charger will appear everywhere you need it . . . were these the same clowns that used to buy those magical fuel mileage enhancing magnets? The theory was OK there too, if you ignored facts, as they do now . . .
Nuje
Island near Vancouver
I've often wondered: Is there enough lithium in the world to support this (theoretical / hypothetically utopian) vision of every car being an electric car?
Google tells there are 60M new cars produced/sold each year (as of 2012), and this guy at Stanford tells me that the average all-electric car requires about 2.4kg of lithium, meaning each year, 150M kg of lithium would be required (rounding up a bit).
There's about 10Billion kg of lithium in the world, so doing some elementary-school arithmetic (10B/150M = 10/.150) gives us about 66.6 years of lithium. And then that's it.
Now sure, we're nowhere close to ONLY electric vehicles (far from it), but even if we were to get to 50%, given the population growth, there's probably still going to be less than 100 years of lithium available on earth....which is fine for you and me, but probably not the great-grandkids.
Can you say graphene?
nwdiver
Texas
Can you say graphene? :)
Myth 9 (Resource Restraints);
In 1995 lithium reserve base was ~8.4M tons
In 2014 lithium reserve base was ~13.5M tons
That's enough lithium for ~5B cars... we're obviously still finding more... and lithium isn't used as fuel, it can be recycled into new batteries.
turbovan+tdi
Abbotsford, BC.
On charging time, you all of should know.
This one is tested and it says 115 minutes for a full charge.
https://transportevolved.com/2014/07/03/fast-tesla-supercharger-charge-electric-tesla-model-s-fast/
Tesla's own website puts it at 75 mins.
http://www.teslamotors.com/en_CA/supercharger
Another article on charging station waits. I already lnked earlier to people pulling out peoples charging plugs and fights breaking out. So much so, they have brought out stickers, key tags that say, [please don't unplug my car, ;)
http://www.wsj.com/articles/tesla-owners-frustrated-by-recharge-waits-1435690694
Walter
I could do that but that's still time, money spent waiting, IE food, drinks etc and its starting to get cold out, rather not risk running out of juice.
If I drive my cheap, polluting TDI, I only have to really stop once, to fill up, vs numerous stops and spending money to pass the time, :p Not prepared for that yet, maybe when I get old and I have more time, lol.
I might one day consider a Volt due to it having a gas engine so the range is massive over a strictly battery powered car.
nwdiver
Texas
Yep... that's why I very very rarely (if ever) charge to 100%. 80% in 40 minutes or 100% in 75 minutes; that last 20% takes nearly as long as the first 80. You're going to have some charge when you pull in... so like I said... a 30 minute stop is all I usually need. You get enough juice to get to the next stop, the car knows the terrain and tells you when you've got enough.
saGhost
Wilmington, DE
I'm glad you stopped to take an objective look at the situation and the technology before offering an unbiased opinion...
Tesla knows the status of every Supercharger in real time. What's more, the cars are all connected to the cell network, and Tesla has been working on getting real time data into the car - in the near future I expect them to be actively bypassing overloaded charging locations.
More importantly, though, I've never read of having to wait for a charger except for the three or four busiest locations world wide (most of which are in so cal.)
Tesla has been focusing their effort on expanding the grid rather than adding capacity to the busiest parts, but they've added secondary locations to the busiest parts that appear to have mostly resolved the waits.
Walter
nwdiver
Texas
LOL... I love all this anti-EV name-calling; Magic, 'non-sense', fairy dust...
Arther C Clarke was right... any technology sufficiently advanced IS indistinguishable from magic ;)
