DuluthRooster
Many people disappear when they screw up. I wish to "man up" before this community with my story.
To give you some background, I purchased my Jetta Wagon from the original owner three years ago with 22,000 miles on it dead stock. I was interested in alternative fuels from the beginning and researched using WVO or building a reactor for B100 production. At 33,000 miles, I decided on the WVO route. I installed the kit that I felt gave me the best chance of success, secured a reliable source of oil, and filtered it reasonably well (10 microns). Fast forward to three months ago and I have enjoyed 50,000 miles of relatively trouble free .10 a gallon fuel. I have saved thousands of dollars as I drive over 20,000 miles a year. All of last year spent $208 on diesel. Many on this board have seen my system and felt my attention to detail was the reason for my success.
I will not mention the brand of the WVO conversion that I had as they have treated me well and have top notch customer service. I was one of their early adopters. I do not think this is their fault.
The first incident happened at 79,000 miles right before I had Paramedick do my timing belt. I had a oil leak that turned out being a rear (crankshaft)seal. That cost me $600 to have replaced.
At 83,000 miles my car started consuming oil to the tune of 1/2 quart every 100 miles. It also ran rough as if on three cylinders and there was occasional unintended acceleration. I determined it was the turbo seals going bad. I thought it might be a good time for a turbo and intercooler upgrade. Kerma recommended his VNT-17 with 52 mm compressor. Landon (TurbineWhine) offered for me to come up to Asheville to change it out but before I could drive up there my turbo started screeching. Afraid to drive it, I flatbedded it the 150 miles. When we pulled the stock turbo off, this is what we found:
[FONT=Verdana, arial, sans-serif]
The shaft was wobbly and the impeller obviously gone. Good I didn't try to drive up!
Here the new Eurojet SMIC. Thanks Kerma.
[/FONT][FONT=Verdana, arial, sans-serif]
And a comparison between the Eurojet and stock. TurbineWhine on the left with yours truly:
Thanks to Landon, Karen (Mrs. Turbinewhine), and son Daniel for the help and great hospitality. Fine people and a good source for TDI repairs in Western NC.
The test drive after new turbo, intercooler, and PP764's was less than fullfilling. My car was just not as fast as it should be. Landon's stock turbo Jetta also with RC3 would just walk away from it. What was wrong?
When I got back home I purchased a compression tester and got the following readings:
[/FONT]
Cylinder 1 - 540
Cylinder 2 - 540
Cylinder 3 - 480 After adding ATF - 535
Cylinder 4 - 240 After adding ATF - 280
Looks like stuck rings or worse.
At this point, I knew this probably wasnt coincidence. On a car that had 83,000 miles, I so far had to do a rear seal, turbo, and now possible rings.
I decided to take the WVO conversion off the car. My new VNT-17 Hybrid was too nice (and expensive) to risk. I put the fuel system back to stock, bought a tank of B100, changed the oil, and hoped the compression would start to come back.
After a short time I consulted with Bruce (Paramedick) and his friend in Missouri, Frank (Franko6). They both felt the additives and flushes wouldn't hurt but that based on their experience with WVO cars, I was ultimately looking at a teardown and cleaning of the the head and pistons. Since I was starting a new job in a couple of weeks, I wanted to get this resolved now. I asked Frank if I could come out to Missouri the next week since he had experince with cars like mine. I secretly thought that Frank might be being dramatic about what could be in my engine because after all, I had a good WVO set-up! What we would find in my engine was much worse.
The car drove good to Missouri and actually seemed to run better. When I got to Frank's he and his friend Randy checked compression and it was a little better. Perhaps I should just flush it some more?
We pulled the valve cover and the cam was scarred. The cam followers were scarred. We pulled the head and found this:
[/FONT] [FONT=Verdana, arial, sans-serif]
[/FONT] The above was somewhat expected. What we found next was not. See part two for the rest of the story.[FONT=Verdana, arial, sans-serif]
[/FONT]
[/FONT]
Cylinder 1 - 540
Cylinder 2 - 540
[/FONT]
