Nero Morg
Well I'm at it once again, working on the 03 NB that was ran on WVO.
The shaft seal had failed on the injection pump and leaked down the timing cover. I have the block side timing cover off and I'm trying to clean up all the coagulated sticky crud off, but not having much luck. Has anyone had some sort of solution for cleaning this stuff?
I did have to change the entire engine assembly, but I'm moving external parts over from the old engine such as the timing cover and the mega bracket. They're both covered in this stuff.
