so on sat evening i caved, had to wait for this morning for the hardware to open, got a few cutting disks, didnt go well, as for one my compressor is a smaller one, also didnt really want to try to find the bigger compressor i have,,somewhere,. also its only a 4"grinder that and i didnt want to go over the 90psi its rated at. so anyway, switched back to the cutter. all the way to the left of the pic was too tight to get the torch in, so i,,took my other fire cloth and tried to cover everything(else) as best i could. anyway made out ok, no major fires, no disaster. (cutting from outside, to inside) cheap insurance those aprons, turned into fire cover cloths, they took a beating. other than smoldering, which i used spray bottles with water. suppressed anything small i made. no major problem A/C lines ok, fuel lines ok too, some damage to electrical outer insulation, probably from prev hack work.
https://farm5.staticflickr.com/4304/35599200060_c0c6b97257_m.jpg
still just getting to post links, not the photo, blaah.
anyways, going to have to de-rust area, and grind. then will metal-prep, then can paint, then i can move to next step. moving along.--.
