Wiring issues on 06 Jetta tdi
Erikknollenberg
Nebraska
2006 Jetta TDi
Recently picked up and 06 Jetta tdi. Had a p0201 code when I got it. Drove it 30 miles with no issue. All of the sudden when I stopped to make a left turn it started to misfire. Looked at the wiring and found frayed wires. Do I need to replace this section of wire? Or can I just “clean” them up and heat shrink them?
Erikknollenberg
Nebraska
2006 Jetta TDi
Wired in new plug still having same issue. Just tested the wiring under the valve cover. Injector harness at cylinder 1 read 0.1 ohms at both wires. The injector itself read 0.2 ohms.
Cylinder 2 injector also read 0.2 ohms. I’m not sure if this is correct or I got a bad reading.
Tested all other wires in injector harness and they are all reading 0.1 ohms.
When I was driving it today to see if the new plug fixed it, it threw the P0201 code and started to misfire. I cleared the code while driving and the misfire went away. I’m at a loss on where to look next.
Rx7145
Ohio
2006 Jetta BRM
Swapping 1&2 injectors would narrow it down to the injector.
