Dan of L.I.N.Y
- Joined
- Feb 13, 2002
- Location
- New York NY
Is this good or bad?
I have noticed that when I put the wiper switch on my '96 Passat in the intermitten position, the delay is about 6 or 7 seconds.
If I toggle the swithch up and down quickly once or twice and return to the intermitten setting the pause between cycles has been reduced to about 3 seconds.
Is this the way it was designed? I know some options offer different intermitten speed settings, depending on the need. Has anyone else had this experience?
To return to the original 6-7 second setting I must turn the wiper off for about five minutes or so. It seems it must be resetting it self to the original settings. Is this speed cycle controled by a programmed setting?
I'll see if the same happens on our '98 Jetta.
Dan of L.I.N.Y
Dan of L.I.N.Y
