nokivasara
Like others have stated earlier, light right foot combined with clutch slip until you get moving.What is your recommendation for starting from a stand still?
When I was in Sweden I noticed that few drivers had AWD. What do most Swedes do for winter driving? I assume winter tires, but do they also invest in tire chains?
When you let the clutch out just stop right when the car starts moving, keep it there for a second or two longer than normal and off you go!
Low revs are important, you don't want more power than it takes to get moving.
I usually start with no throttle at all.
In a intersection when there's almost no grip at all you can let the tires spin slowly and turn the wheels from side to side to seek traction.
When you park your car on loose snow you can drive back and forth a few times, just a bit, 30-50cm (1-2ft) to compress the snow under your wheels.
This help in two ways:
1. Whenever you park your warm tires melt the snow underneath and the tires sinks down in the snow and you're likely to get stuck before the car moves at all. When you pack the snow it won't melt as much if at all.
2. The 30-50cm of packed snow acts like a launch ramp when you start, just get in and start as usual, you won't get stuck.
What do swedes do for winter driving?
Snow/winter tires are mandatory from december to april, all season tires are not legal during winter. This helps of course. I have never seen anyone with chains.
We have to practise on a slippery test track (and pass) before we get our driving license.
Other than that I don't think we do anything special, we are taught to take it easy when driving in snow
Remember that aggressive driving and winter does not match very well, no matter if you want to accelerate, brake or change direction (cornering, changing lanes and such) always do it with causion. Always.
A TDI has a powerful engine brake, use that whenever slowing down.
I'm sure some people doesn't agree with me and that's OK but I have never been off the road or needed someone to pull me out when I was stuck. I have always managed to get going without help. I have had to use the shovel I bring with me more than a few times though!
