doubledls
- Joined
- Jun 30, 2002
- Location
- jackson county, michigan
- TDI
- Jetta, 1999.5 A4, black, 2009 Jetta 6 M, black
Folks:
My 1999.5 Jetta wipers had no high speed to answer the heavy rain today. They will work at low speed, and intermittent speed, and when you hold the switch down or use the washer. At high speed they just move a wipe or two and then stop in the middle for about 6 seconds and do it again. Even the low speed seems a little slow. If a run it long enough at low speed it will also occasionally stop for six seconds and then resume running.
I checked my volts when running (14.1 V) and the battery was reading 12.66 V with the engine shutoff. I also took out Relay 377 and put it back in as it looked OK. I then looked at the the wiper motor assembly and motor and it looks and moves OK.
Has this happened to any one else? Is it a relay problem or a motor problem? Both will be 9 years old in about 6 weeks. What does Relay 377 cost?
