gte824j
Hi Everbody. I have (2) questions on a couple issues which are unrelated. TDI is '02 Golf 5-speed.
The first issue has to do with the replacement windshield nozzle I ordered. Part Number 6E0-955-985-B. The wiper fluid line coming through the hood seems to be missing the female connector on the end that accepts the nozzle. I am unable to attach the replacement nozzle. I'm displaying a photo below of the female connector that is in-tact on my one functioning nozzle(passenger side). Is there any way to order this female connector piece? Are the nozzles different from passenger, driver's side?
Female connector I'm looking for:
The other issue has to do with a loose vacuum hose which has seemed to work its way loose. Does anyone know where this vacuum line goes? It has a green-colored dashed line on it and originates from a T fitting. I removed the intake hose in order to take this photo. The car seems to be running fine. I haven't noticed any changes in operation or performance. Last weekend, I did perform the glowplugs 101 troubleshooting procedure and I may have unknowingly dislodged this hose while unplugging the coolant temp sensor. Here is a photo of the loose vacuum hose. You'll notice the loose end is lying just above the MAF sensor for display purpose.
