Will VW ever abandon the rotating knob in favour of the tilt handle?
itsfatboy
GTA
Jetta 2006 dark dull
Man, nothing is more outdated and annoying than VW's continued usage of the rotating knob to tilt the passenger seat. Can't those engineers get this fixed? I mean, they were smart enough to move the cup holders on the 2003 that covered the radio controls...
Come on VW....drop the knob !
Antsrcool
MA Springfield
2010 Cup Edition
i like the dial because with the lever you get like 10 settings that are locked into. with the knob you have unlimited settings.
itsfatboy
GTA
I am looking at the '11 Trendline Jetta TDI.
hopefully they changed it...it was the same in my 03 and 07 jettas
NovaMoto
Halifax, Canada
'11 TDI Golf
The lever in the new golf adjusts the seat via an infinitely adjustable electric motor.
A pleasant surprise!
MayorDJQ
Williamstown, Mass
'10 Golf 2dr 6m, sold.
My '09 Jetta had an electric adjust for the tilt function. My '10 Golf has knobs. It doesn't bother me. How often is it necessary to adjust the tilt more than a few degrees at a time?
tcp_ip_dude
Cape Fear area, NC
2010 Jetta TDI Sedan
Only 'knob' on mine is for the lumbar support, all other settings are switches/levers (both seats). Seat rake is electrically controlled.
SpamJ
Cable, MN
Jetta Wagon 2002 Silver
My Theory on the knob was that the Germans didn't want people to pull a lever and not be able to control a car as the seat back dropped to horizontal.
compu_85
Gadget Guy
La Conner, WA
... None :S
I'm sad to see the knob go away. It make it much easier and safer to make a small adjustment to the seatback while driving (which I will do several times on a long multi hour drive).
-J
TwoTone
DMV
05.5 Jetta (sold)
Outdated, really? It's a much better system that a lever. Knob gives you infinite adjustment, lever has a tooth/notch that must mesh so you only get so many possible adjustments.
I've driven cars that piss me off because I find the seat comfortable right in between two notches.
