AtomicSushi
I got my hands on a GT1749V and manifold from a PD115 for pretty cheap and was wondering if the exhaust manifold would just bolt right on in place of the ALH one?
I disagree. (I think!)My ALH engine came with a GT1749V. So you shouldn't have any problem fitting it in, but I don't think you're going to gain much with this mod. A stock ALH has already more than enough air available, all you need is more fuel.
No, it's just that we don't have the same definition of "stock". By stock I mean not only stock air intake, but also stock injection system, ie no chip or injectors or evry mod. In that case, no matter how much air you flow in there, should you use a VNT 19 or 25 or pressurized liquid oxygenI disagree. (I think!)
Right. I should have been more specific.Now if you have a modded injection system (which is AS's case, I should have checked that sooner) with a "stock" intake and put in enough fuel to have some unburnt, you indeed need more air in there. <font color="blue"> *snip* </font> All this also implies you modify the requested boost from the ECU, else this is completely pointless.
