Check if the shutdown valve is stuck in the closed position. If it is...EGR and intake cleaning time.pmich said:Could a cloged manafold/EGR be behind this?? I will turn over on first crank and then ZIP on second... No Codes and was running fine untill just now.
I didn't know about the surface charge until I started researching it recently.How to test a battery said:You must first have the battery fully charged. The surface charge must be removed before testing. If the battery has been sitting at least several hours (I prefer at least 12 hours) you may begin testing. To remove surface charge the battery must experience a load of 20 amps for 3 plus minutes. Turning on the headlights (high beam) will do the trick. After turning off the lights you are ready to test the battery.
