mozark
- Joined
- Aug 7, 2018
- Location
- Mon Nat'l Forest, West Virginia
- TDI
- '05 Passat Wagon, Silver, 5sp '05 Passat Wagon, Indigo, auto
In this case a potential geared BSM failure?
I did not own the car at the time the low oil pressure warning flashed. The only engine faults are two glow plug P0674 electrical faults, and a coolant temp sensor P0118 intermittent signal error. (There are also central convenience faults, a couple of control module supply voltage, and a bunch of door control faults,)
There are about 80k miles on the geared BSM.
Curious if there's possibly a simple answer before I remove the oil pan.
thanks,
MM
thanks,
MM
