will 15" rims fit my 98 jetta
DUG
Ephratah,NY
I'm looking for a set of steel rims for use in the winter. My 98 jetta has 14" now that I'm happy to run in the summer.
I have a set of 4 very good snows but there 15" tires , so my question is; Does anybody out there have a set of 4 15" rims that will fit ?
I would also consider buying a set of 14" steel rims and snows if they are avalible.
I'm a new owner of a TDI , but not a stranger to diesels as I have been a happy owner of a dodge /cummins diesel for many yrs.
GoFaster
Moderator at Large
Brampton, Ontario, Canada
2006 Jetta TDI
Offset and hub diameter have to be correct, too. But anything suitable for a 4-bolt front-drive VW will work. I have 15" aftermarket alloy wheels for mine.
I believe that 4-cylinder Corrado models came with 15" steel wheels with the 4-bolt pattern.
DUG
Ephratah,NY
OK thanks for the info
If anyone has a set that they think will fit , I'd like to hear from you.
15" is preferrred, but I would consider 14" rims.
DUG
Oo-v-oO
Live Free or Die, USA
98 Jetta Expired... Now 2000 Golf & 2002 Golf
What size are the 15" tires? I'm willing to bet unless they're an oddball size they will be too tall for the car. At the very least they will be taller than the originals and will throw the speedometer and odometer off.
IMHO, you're better off going smaller in rim diameter for snow tires. I think the taller sidewall is a benefit in snowy conditions. Plus, it gives more of a cushion on the rotten frost heaves.
-Lee
bowlerman
medford, NJ
2001 jetta tdi black
put 15 rims on mine and they look great. borbet type h and 50000 mile warranty tires! i should be good for a while
weasel
Deactivated Member Account
None.
My summer tires are 195/60/15 and the extra diameter actually corrected both the speedometer and odometer ...
lrpavlo
Cocoa FL
09 Sportwagen DSG, 02 NB Auto
my summer tires are the same as Weasels....my calculations show the speedo dead on but the odo to by shy 2miles for every 50 traveled.
DUG
Ephratah,NY
I just ck the size of the 15" tires and they are bigger .
I guess I'll stick to the 14" wheels for my winter rubber
Thanks for your thoughts
DUG
Steve Addy
Iowa
97 Mk3
I run 195/55vr15's in the summer, 195/60r14's in the winter, both on alloy although I think the steel rims that were on it originally weighed less then the 14" GT alloys I use for winter now.
steve a
