doonboggle
- Joined
- Jul 2, 2007
- Location
- Elgin, Texas
- TDI
- 2006 Jetta w/Taktonic 6sp. transmission, Silver; 1981 Rabbit pick-up
http://www.thecybertruckstop.com/DS/fuelprices.html
So, if biodiesel is such a great thing why not just use pure biodiesel? Well, there are some cases in which pure biodiesel (B100) is appropriate but, at least for commercial trucks, the use of pure biodiesel can cause some problems. For example:
- Gelling Temperature: Biodiesel gels at a higher temperature (32 degrees) than standard #2 diesel (-15 degrees). This isn't a problem with biodiesel/petro-diesel blends of 20% or less (B20 - B2) but it makes the use of B100 unworkable in a commercial vehicle.
- Lower BTU Rating: A BTU (British Thermal Unit) is defined as the amount of heat required to raise the temperature of one pound of water from 60° to 61°F at a constant pressure of one atmosphere. A study done by the University of North Dakota indicated that, while there are significant fluctuations, #2 diesel contains about 140,000 BTUs per gallon while B100 contains about 130,000 BTUs. (B20 contains 138,000 BTUs.)
- Higher Nitrogen Oxide Emissions: Since biodiesel contains no nitrogen, the increase in NOx emissions is probably due to the higher cetane rating and the high oxygen content of biodiesel. These two qualities are thought to cause the nitrogen contained in the air to be converted into NOx during combustion.
- Higher Solvent Properties: Because biodiesel acts as a solvent it's likely, when used in an engine that ran previously on petro-diesel, that any sediment in the fuel system might be washed into the engine's filters and fuel injectors. Rubber gaskets and hoses will also degrade at a higher rate. This means that filters will need to be changed within 1000 miles of changing to a biodiesel blend and the hoses and gaskets will eventually need to be changed to something that doesn't react to biodiesel; like Viton.
